Results 1 to 4 of 4
Thread: Shaping edge on disk
    11,825
    Yesterday I was trying to make a project for my son. It involves two oak disks I cut on the bandsaw then trued on the lathe. I then tried to put an ogee on the edge with my mini shaper. I understand that with a circle I am cutting end grain about 99% of the time. Sadly, I couldn't do it. Invariably the shaper caught and ripped off a chunk of the disk.
    Any suggestions?
    BTW, I am considering recutting disks and just using the lathe to put an edge on them.
    30,002
    Are you trying to cut the entire profile in a single pass (and thus taking too big of a bite with the shaper cutter)? With that much end grain exposed (especially on oak), you might indeed be better off doing the edge on the lathe.
    11,825
    Yep. That is what I have decided. However, these are on 1/4" thick. I am going to go with plain ole pine and 1/2" wood for a redo. Doing oak end grain on the shaper, I believe, will always give fits.
    Feb 2012
    central florida
    208
Name:	chair risers.jpg
    I had to make a set of discs to use as risers for a couch. basically 2 discs for each leg so 8 total. it was 3/4" oak and all of the discs got a round over edge. I did them in 2 passes and only had a tiny bit of tear out in like 3 of them Almost all of it sanded out
    I am betting a round over is little easier than a simple ogee but I'm thinking not that different.
    I'm thinking the bit might be a little dull or something else. Some thing tells me you can do it in oak. I mean if I can it can not be impossible. I'm not that good.
  1. shaping and safety question
    Last Post: 10-11-2013, 04:57 PM
  2. Shaping sharpening skills
    By Ken Cook in forum Turning Tool Questions and Show & Tell
    Last Post: 06-18-2011, 03:33 AM
  3. Holster shaping
    Last Post: 04-06-2011, 11:33 PM
  4. Shaping Maple Panel
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 06-29-2010, 05:26 AM
  5. Shaping Small Pegs - Method?
    Last Post: 08-09-2007, 11:24 PM
