Results 1 to 8 of 8
Thread: Bench Touch Up
    15,815
    Bench Touch Up
    My bench, is really a work table, and it has a plywood top.
    I usually take the ROS to it about once a year just to remove the glue and other stuff that gets on it. I also refresh the wax coating I put on it, helps (for a while) to keep things sort of clean...........
    Here it is before I did anything to it, well besides make it a really dirty mess
    I started with a #80 pad, and then went to a #120, not much point in going beyond that, I think
    next I slathered on a thick coating of wax, basically put it on until I had a film of wax built up on the surface. At first the freshly sanded plywood sucks up the wax, but after a while it kind of builds up, at that point, I take a green scrubby pad (Scotch Brite?) and stick it on the ROS, I then go at it with this, it heats the wax up a bit and really pushes it into the wood.
    After letting it dry, overnight, I take a buffing pad on the ROS to the table top, this takes only a few minutes, and the top, while not "Shinny" is a lot smoother and cleaner than before.
    I know this is not "Fine Woodworking" but you CAN renew a plywood bench or table top to a working condtion, a few times at least.
    Nice to have the bench all clean again!
    stu, want to come visit? my bench needs a tune-up too
    15,815
    Visit, yeah, I'd love to, bench tune ups, sorry, you are on you own!
    Northville, MI
    507
    Stu, you ruined it. Now it has no character.
    Jim
    Tokiwadai, Japan
    2,882
    Nah... I think the "after" one looks like a nicely worn leather jacket you've had, and used, for many years.... Good memories with it.
    okay man........spring cleaning .......a freash coat of lacquer and dusted with the air gun.....
    3,147
    Heck that would take up 1/2 my shop Tod at only 13'5" x 24'5". Great looking bench.
    Say Stu great lookin plywood top too ain't nothin wrong with that. Well aged, must be something like your beer & cigars.
    15,815
    Geez, that is a keeper Tod!
  1. Touch up
    Last Post: 08-09-2011, 09:01 PM
  2. Touch up are done
    Last Post: 03-25-2011, 05:37 PM
  3. Repurposed bench materials - dedicated sharpening bench
    By Darren Wright in forum Carpentry and Construction
    Last Post: 12-31-2010, 05:25 PM
