Results 1 to 5 of 5
Thread: talk to me about hypoallergenic finishes
    hi all
    I've been making eye glasses and finishing them with Salad Bowl Finish. Looks great, guaranteed to be completely non-toxic when cured, they use it to finish wood toys, so I don't have to worry about it irritating anyone's face. But it smells like finish which is something I'd like to avoid.
    Here's what I'm looking for:
    • hypoallergenic/non-toxic
    • minimal "finish" look
    • protects the wood from face's oils
    • minimal odor
    • clear
    any suggestions?
    Jun 2007
    4,944
    Hi,
    Shellac or Seal Coat (which is de-waxed shellac). I do not know about hypoallergenc as far as skin goes. However, they do coat pills, chocolate candies and a bunch of other stuff with it. It stays clear. It is easy to apply. If damaged by a scrape, abrasion, etc., it is very easily repaired (wipe it with DNA). It does not yellow.
    Check it out on the web. Glenn uses it a lot and is more familiar with it than I am.
    I have never tried it but I wouldn't be surprised if you couldn't repair an abrasion with a soft cloth and whiskey.
    I'm not sure it is worth 2 cents, but that's my 2 cents worth.
    Enjoy,
    JimB
    VOTING MEMBER
    I'd suggest using a water-based polyurethane. It will be more durable, it'll also be non-toxic when cured*, and it won't have the "finish" smell that oil based polys (like Salad Bowl Finish) do. Personally, I'd not use shellac. Although it's non-toxic when cured, it's not as durable as poly. Also, I suspect skin oils would shorten it's life even more.
    * In my opinion (and I realize some will disagree), the "non-toxic" aspect of Salad Bowl Finish is nothing more than marketing. Virtually all modern film finishes are non-toxic when cured. As far as I can tell, the only difference between Salad Bowl Finish and regular oil-based poly (that's been thinned) is that the manufacturer has paid some lab somewhere to test it and certify that it's non-toxic.
    thanks for the insight. Being from Milwaukee, I'm going to try out some General Finishes water-based poly tomorrow.
    lot of good info on this site, but also a lot of really good avatars.
    Jun 2007
    4,944
    Quote Originally Posted by Josh Rickun View Post
    Does that mean that you like the pic of me after my first airplane ride? (1929).
    Enjoy,
    JimB
    VOTING MEMBER
  1. Catalyzing finishes
    Last Post: 06-28-2010, 05:24 PM
  2. Finishes that are different
    Last Post: 05-11-2010, 03:16 PM
  3. Finishes for Gun Grips
    By Darren Wright in forum Finishing School
    Last Post: 04-20-2010, 12:47 AM
  4. Please help me decide what finishes to use
    By Joe Provencher in forum General Woodworking Q&A
    Last Post: 12-18-2009, 12:11 PM
  5. Finishes for turning
    By Drew Watson in forum General Woodturning Q&A
    Last Post: 11-24-2009, 06:20 PM
