Results 1 to 10 of 13
Thread: The panel chest, start to finish. (well almost)
    Rochester Hills, MI
    940
    Still trying to decided on the color, but here's a pictorial review of my latest chest project from start to finish. I bought the material Monday morning, and I took these shots at around 12:30 on Wednesday. I really like this one and I hope it sells so I can make more. That Kreg pocket hole jig makes projects like this a breeze!
ID:	74316Click image for larger version.
ID:	74317Click image for larger version.
ID:	74318Click image for larger version.
ID:	74319Click image for larger version.
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten"
    Rochester Hills, MI
    940
    Part two. Here are the rest of the pics.
ID:	74321Click image for larger version.
ID:	74322Click image for larger version.
ID:	74323Click image for larger version.
ID:	74324Click image for larger version.
    new york city burbs
    10,184
    are you kreg screwing the stiles and rails together then rabetting out inside to inset panel?
    Human Test Dummy
    Rochester Hills, MI
    940
    Yep, that's how I did this one. Actually, After the rails and stiles were all assembled and sanded, I used a chamfer bit on the outside and put a little bit of a bevel on the outer edge. Then I used a rabbeting bit to cut the rabbets for the panels. Then I set the panels in place and used some 1/2" material with a 1/4 x 1/4 rabbet and ripped it down to 3/4 wide. I used that to hold the panels in place. In the future, I'll probably cut a slot in the rails and stiles and then just insert the panels as I assemble the piece. The way I did it took a little more work, but at this point I was more concerned about what the piece would look like on the outside.
    new york city burbs
    10,184
    yeah, I was looking at the inside, was wondering why you didnt just use some small pins and glue and hold the panels in place, but then I realized how visible the inside is also.
    Im thinking of making the wall panels for my attic bedroom the way you did it. Kreg screw it all together, then rabbet out the back for panels. Id only pin and glue them in place since its going to be secured to a wall.
    I believe the chest is certainly a winner, hope you sell alot of them
    what species is it made out of? pine, maple or poplar
    Human Test Dummy
    Rochester Hills, MI
    940
    The panel sections are made with solid poplar and 1/4" birch ply. The legs and trim are all solid poplar. The back, bottom, and lid are 3/4" Birch plywood. Now that I know it works and looks OK, I think I'll just cut 1/4" slots in the rails and stiles before assembly. Then glue and screw the bottom rail and stiles in, slide the panels in, and then secure the top rail.
    5,317
    Quote Originally Posted by John Pollman View Post
    ...Now that I know it works and looks OK, I think I'll just cut 1/4" slots in the rails and stiles before assembly. Then glue and screw the bottom rail and stiles in, slide the panels in, and then secure the top rail.
    That's how I'd do it. I'd also cut the stiles a bit long and put tenons on both ends. Run the dados (slots) full length in the rails, and only put glue on the stub tenons of the stiles. Let the panels float.
    Rochester Hills, MI
    940
    It's all done and listed on Craigslist!
    I hope to sell a lot of these, they're really fun to build.
ID:	74418Click image for larger version.
ID:	74419Click image for larger version.
    Oliver Springs, TN
    1,726
    John, if you don't mind me asking. What are you wanting for it on CL? I've tried to sale a few things on CL around here and found that people are looking for yard sale prices or less.
    I also hope you sale a bunch!
    Rochester Hills, MI
    940
    I put it up on CL for $450. We'll see what happens. Personally, I think that's a fair price for a piece like this. Maybe I'm out of my mind, but I don't think you'd go into a furniture store and buy a piece of comparable size and quality for less than that.
  1. Shearing Sheep: 20 seconds start to finish!!
    Last Post: 06-19-2008, 12:27 AM
  2. How to fix drawer guides/runners on a frame and panel chest?
    Last Post: 01-14-2008, 07:40 AM
  3. Frame and panel chest of drawers question.
    Last Post: 11-23-2007, 06:44 AM
  4. Frame and panel chest of drawers
    Last Post: 10-11-2007, 01:23 PM
  5. And with the end of one, the start of another!
    By Lee Thomas in forum Old Iron
    Last Post: 05-06-2007, 05:08 AM
