Results 1 to 3 of 3
Thread: Sanding station question
    Palm Springs, Ca
    1,166
    Regarding the craftsman sanding station I cleaned up and got running - I ordered the belt that showed it was a 6 x48 inch - I tore it trying to slip it on - the guide rollers were all the way in and it was very tight and all of a sudden ripped in two - Wondering if I was doing something wrong or is there a 50" belt out there ??? I thought all you did was to push the end with the rollers all the way in - slip it on - tighten it back up and call it done...............any suggestions ?
    Ill look to see what the next biggest size is I guess.................Thanks Dan
    17,470
    dan there is a lever on the side that shortens the rollers length and you can easily slide on a new one release the lever and your ready to go unless you need to adjust it to run straight with adjustment knob.
    Palm Springs, Ca
    1,166
    Yeah I found adjustments and I had not loosened up the the bolts enough......thanks
  1. Craftsman Disc Belt Sanding Station Story
    Last Post: 03-01-2013, 06:45 PM
  2. Dying, Photo Set-up and Sanding Station
    By Nate Davey in forum Lathe Project Showcase
    Last Post: 01-22-2013, 02:41 AM
  3. S.S. Power station work center / with 12’’ sanding disk
    By Richard Poitras in forum Classified Ads
    Last Post: 06-02-2012, 02:26 AM
  4. Belt Sander - Sanding Shoe Question
    Last Post: 09-30-2009, 04:54 PM
  5. Dog Feeding Station
    By Brent Dowell in forum Flatwork Project Showcase
    Last Post: 11-20-2008, 03:04 AM
