Results 1 to 7 of 7
Thread: Bob got new boots!
    13,364
    Bob got new boots!
    The old ones had pretty much zero tread left. In fact they were flat, and I had no way to fill some of them up with air!
    In this picture you can see an oval spot on the inside right of the rim where the filler tube should have been, but it was sheared off.
    So not only was I not getting traction with my bald flat tire, the tire would spin around on the rim. They were filled with rubber foam, so it wasn't like they were flat on the ground, but they were shot.
    And with that rubber foam, they were heavy, and not really worth trying to just get new tires put on.
    So I ordered a new set of tires off ebay. Definitely the budget models, but they should work for me.
    The offset is a little different than the old ones, but since it's a little wider, that's fine with me. Should make it a little more stable.
    Now Bob will have better traction and a little higher, wider, more stable ride!
ID:	74389Click image for larger version.
    Looks good, Brent.
    13,464
    That should help!
    4,553
    Yeah what Logan said....... he seems to approve
    A Turn N Time
    Frog Pond Guitars
    13,364
    Quote Originally Posted by Jay Caughron View Post
    I think logan was scoping them out for other reasons.... LOL
    5,323
    Much better tread, but, installed, they do look a bit narrower. Shouldn't affect operation, though.
    Are these foam-filled, too? That sure beats getting flats - but then, you're less likely to be running over nails, etc., in a construction site than commercial operators would.
    13,364
    No, just regular old 10ply pneumatic. So far I can tell there is a huge difference in the ride. It's actually less bouncy but more precise? Not sure that makes sense, but new shoes always feel different.
    Filling them with foam would have added a bunch to the price, and like you said, it's not like it's going to be used at a rental yard or construction site, so I didn't figure I needed it.
    I gave it a little digging test and I can tell there is better traction.
  1. Google getting too big for its boots
    Last Post: 04-25-2015, 04:05 PM
  2. Boots in the shop -
    By Doug DeVore in forum Off Topic Discussion
    Last Post: 12-21-2011, 02:47 PM
  3. Shopping for snake boots for Denise and I...
    By Marty Walsh in forum Off Topic Discussion
    Last Post: 08-20-2008, 05:45 PM
  4. Uh. I "soiled" my boots...
    By Greg Cook in forum Off Topic Discussion
    Last Post: 03-26-2008, 10:34 PM
