Results 1 to 10 of 29
Thread: Is granite a good router table top?
    Feb 2012
    central florida
    208
    I came across a 5 foot by 4 foot granite slab from for a counter top that is cheep enough for me to use for my new router table. I know these things are pretty darn flat but how do they fair as a work surface.
    I know its tough enough. but does the work slide over it very well?
    Is it too hard to mortise the router plate into and how much would the bit cost to do that? Would the bit be so expensive that its not worth it?
    any input would be appreciated.
    4,552
    Steel City Tools use Granite for the machine tops so I would think it would work. BUT I would contact a Granite co and have them machine the area out for the router and such you cant use regular bits they are diamond bits and have to run in water.
    A Turn N Time
    Frog Pond Guitars
    17,472
    i will second the fact on having the granite company cut out the hole, so you should get your inset top first to have the right fit.. wood should slide across it very nicely..
    NH
    4,005
    I wont third that but I'm a different breed and cut stone on a regular bases.
    If you don't have the stuff and don't have any experience messing with stone take it to a granite counter top place and have it done. Ok so I third that
    Stupid hurts.
    Feb 2012
    central florida
    208
    I have cut stone but only along an edge. I have polished it also but that isn't anything like rabbiting a square hole at a specific depth.
    I wasn't thinking of getting any one else involved because of the cost. I bet having some one do the hole for me would be more than the granite. I would only be paying $75 for a 5' by 4' slab. thats why I wanted it. that and the fact I know it will be flatter than anything I build.
    Chuck: I have the template that comes with the router plate I want to use. If I had a diamond bit, would it last long enough without water to make the rabbit I need?
    I was thinking this http://www.toolocity.com/diamond-fin...-12-shank.aspx or maybe 2 of them because they are cheep.
    30,017
    Apparently there are carbide bits that'll cut granite without water:
    http://www.2linc.com/tools_armor_mill.htm
    Feb 2012
    central florida
    208
    I don't know if that will work well enough on removing a lot of material. looks like it would handle lettering but that seems lighter work than what I need.
    S E Washington State
    3,777
    I don't think it would cost much to ask if a counter top/granite shop what they would charge to do the hole. You might be pleasantly surprised, than again maybe not.
    "We the People ......"
    NH
    4,005
    Quote Originally Posted by keith Boutselis View Post
    The only way to find out is to buy one and see what happens. I have gotten bits and blades that have been stellar and I have gotten ones that where junk right out of the box. Most of the stellar ones I have had cost the long dollar.
    Stupid hurts.
    13,361
    If I could get a 4'x5' slab of granite for 75$, I'd buy it and figure out what to do with it later.
    You could always cut chunks to use for Scary Sharp Sharpening.
    That's a bargain, and I agree with Paul, it wouldn't hurt to ask how much to get a hole rabbeted in it.
  1. Router table router recommendations - What are your experiences?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 11-11-2012, 04:27 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 02:02 AM
  3. Ridgid's new R4511 Granite Table Saw
    By Kevin Vernon in forum New Tools
    Last Post: 02-04-2009, 08:47 PM
  4. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
  5. Granite is good for turning!
    By Lee DeRaud in forum Lathe Project Showcase
    Last Post: 03-13-2007, 11:52 PM
