Results 1 to 10 of 14
Thread: Home made zero-clearance inserts are a breeze!
    Rochester Hills, MI
    940
    My TS is an early to mid 70's Craftsman and the insert has a fairly wide slot in it. I looked at the wide variety of zero clearance inserts at Woodcraft but didn't have it my current one with me to compare. I got home and realized I had a nice piece of 1/4" masonite sitting around doing nothing so I decided to put it to work. It was very easy to make the blank and get it to fit. Once it fit, it was just ever so slightly above the table. I put a 1/2" rabbeting bit into my trim router and made a pass around the under side of the insert. I took off less than 1/16". I popped it into place and it fit PERFECTLY! I saved a nice chunk of change and things just got a lot safer working with my TS. I think I'll take the $$ that I saved and buy a GRRipper.
Name:	zero clearance 1.jpg
ID:	74576Click image for larger version.
Name:	zero clearance 2.jpg
ID:	74577Click image for larger version.
Name:	zero clearance 3.jpg
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten"
    Sep 2007
    Plainwell, Michigan
    4,855
    Looks good John a GRRiper would sure be nice on the insert, drill a finger hole with a Forster bit, will make much easier to remove
    13,437
    Feels good to save money on stuff like that. I've made mine for a while now. That MDF can be drilled and tapped to put set screws in them for adjusting the height as well. When one gets pretty worn out I'll just make a another and re-use the set screws. I've made them for the older craftsman like you have. If I remember correctly, there is a recess in the table on the back that a nub on the factory plate goes into, which keeps the back of the plate from lifting up. If yours has that spot, I just drilled a small hole in the back and inserted a #4 or #6 nail and cut if off to about 3/16"-1/4" long to hook into that recess and keep it from lifting out. I may have some pics, will look to see if I can find them.
    Independence, Kentucky
    1,354
    Good job John.
    I make mine also for my old Craftsman saw, I used the original plate from my saw to make a mdf pattern, then I use my vacuum pump attached to the pattern to make my inserts with my router table, it works like a charm and you can crank out quite a few in a short time. Cheap and easy to do. I attach a fender washer under the back side to keep the plate from raising up in the back as a safety measure.
    30,008
    Well done, John. You're gonna really like the difference a ZCI makes in your cutting, especially ripping thin strips.
    13,357
    Rochester Hills, MI
    940
    Thanks for the input folks. I took my time and made this one fit pretty snugly I set it in place and actually have to tap it down to get it in. Once it's there, I don't think it's going anywhere. When it comes to removing it, the back of the saw is open. I can just reach in there and tap on it a few times with something and it will pop out.
    Rochester Hills, MI
    940
    I just made another one. (for 45 degree miters) I did see that there's a little area near the rear for that clip to catch on. I think that I'll come up with something to engage that lip at the rear. It will keep it safely in place.
    12,247
    Dec 2012
    Bedford, NH
    1,683
    Quote Originally Posted by John Pollman View Post
    Nice job! Something I may copy on my next TS. Is the insert finished or raw masonite? I think masonite is reasonably stable both temperature- wise and humidity-wise, and probably doesn't need a finish, but not sure.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
  1. Home made I-socket?
    By Ninh Shepherd in forum General Woodworking Q&A
    Last Post: 01-06-2014, 03:48 PM
  2. FREE Zero Clearance TS Inserts
    By Jim C Bradley in forum Giveaways, Contests, and Swaps
    Last Post: 04-04-2013, 10:27 PM
  3. My Home Made Hollow Rig
    By Wayne Bower in forum Turning Tool Questions and Show & Tell
    Last Post: 04-23-2008, 11:12 AM
  4. My First Home Made Tool
    By Pete Jordan in forum Turning Tool Questions and Show & Tell
    Last Post: 03-28-2008, 12:09 AM
  5. Home Made Handles
    By Tony Falotico in forum Turning Tool Questions and Show & Tell
    Last Post: 11-07-2007, 08:16 PM
