Results 1 to 10 of 20
Thread: name of a supplier or the company
    17,472
    that makes prefinished plywood, done a search and had no luck for a local distributor. so would like to contact a company that sells it to see who is a distributor in my area. asked a local lumber yard and he wasnt even aware it was available.
    May 2011
    Cape Cod, Ma.
    1,553
    Larry Im pretty sure the brand I get is Columbia.
    This is the supplier I get it from, unfortunately the farthest west they are is NY. But, all the pertinent info you need should be on their website to find a distributor in your area.
    http://www.atlanticplywood.com/columbia.asp?
    17,472
    whats the product name rich? i didnt see it listed as prefinish plywood? well i think i found the name, but i do have another question rich, how does spraying lacquer on the face frames affect the prefinished plywood?
    3,132
    Larry i looked at the link, and under plywood they have prefinished ply.
    13,361
    Here's a couple of links. Try the second link and plug in MI into the state.
    Looks like they have wholesale distributors in several locations.
    http://columbiaforestproducts.com/Locations
    http://columbiaforestproducts.com/Wholesale
    Wagner Wood Products, Inc.FSC® certified
    80 W. Lakewood Blvd.
    Holland, MI US 49423
    616.392.8501
    2.
    Victor S. BarnesFSC® certified
    1927 Will Avenue N.W.
    Grand Rapids, MI US 49504
    616.361.7351
    3.
    All American PlywoodFSC® certified
    18840 John R St
    Detroit, MI US 48203
    888.759.9663
    4.
    Amerhart Ltd. - Traverse CityFSC® certified
    5763 S. Bates
    Williamsburg, MI US 49690
    877.700.5190
    5.
    Bond Plywood, Inc.FSC® certified
    988 East Saratoga
    Ferndale, MI US 48220
    248.548.3150
    17,472
    thanks guys..
    17,472
    bump, to find out how the spraying of face frames affects the prefinished insides????
    May 2011
    Cape Cod, Ma.
    1,553
    what I do Larry is prefinish the face frames before putting them on the boxes. Then, I use cork pads on my clamps and apply just enough pressure to hold them while I run in the pocket screws. Works great and I dont have to mask anything off. I build my boxes first then size my face frames accordingly, do all my machining and then prefinish.
    local craft supply I get 6x6 1/4" thick cork and cut to fit the size of my clamps
    N.E. Arkansas
    374
    Larry, most of the places I get the prefinished stuff from call it UV. It stands for ultraviolet cured polyurethane. I get mine from Cedar Creek Lumber out of Tulsa OK. I do like Rich and finish my frames before assembly. I did the assembly then finish for a long time but spraying the UV will result in an overspray that will be a bit rough to the touch. I used to clean that up with a bit of 220 sandpaper but it took the sheen off the UV. I dado all my faceframes to recieve the plywood with a 1/2 x 3/8 groove, finish the frames and assemble face down on a wool carpet. As long as I keep the carpet clean and free of hardware I don't get any scratching.
    I once heard that cats and women will do darn well what they please and that men and dogs would do well to accept it and just go on.
    17,472
    well did some checking and they folks around me wont sell a few sheets they want a unit or not at all. so i quess i am back to spraying inside the boxes.. thanks for the insight on this..one would think that a supplier could sell a few sheets but they say it scratches easily so they wont do it..
  1. Philadelphia Opera Company
    Last Post: 07-02-2010, 10:32 PM
  2. Misery Loves Company
    Last Post: 06-16-2010, 04:19 PM
  3. The trucking company called...
    By Bill Grumbine in forum General Woodturning Q&A
    Last Post: 10-16-2007, 01:45 PM
  4. I love the cable company
    Last Post: 06-30-2007, 10:36 AM
  5. Had some company today.
    By Nancy Laird in forum Off Topic Discussion
    Last Post: 06-25-2007, 03:16 PM
