Results 1 to 10 of 11
Thread: non slip mat problem!!!
    17,470
    Ok you can buy this stuff in a black 24x48 or you can get larger sizes at some department stores.. but here is a problem that gets me every so often and am looking to solve it.. i lay a piece on it for protection while i am working on it and after i set it back up, i got dark spots all over like it has leached oil into the wood like the irwin plastic padded clamps do.. another gripe of mine.. so if anyone has a fix for this to end my troubles, i would like to hear of it. thought of washing the mat in the washing machine and see if that takes out the oily stuff? but i dont think i can put clamps in there
Name:	non slip-oily.jpg
ID:	74668 Click image for larger version.
Name:	non slip-oily-2.jpg
ID:	74669 this is a worst case scenario...
    5,317
    I've had the same problem. Sure hope somebody comes up with the cure!
    17,470
    on the clamps so far i have taken and used painters tape for temp fix.. it works but i cant believe they havnt tried to fix this by now.. it only takes a few mins to get it to.. the only way i have come up with fix it is lacquer thinner or DNA and if that doesnt get it all, light sanding again!!!
    Apr 2008
    We now divide our time between southwest Florida and southwest Vermont.
    137
    I have only used the tan stuff, usually in 12" wide rolls. Never had the problem you describe. But I did get some sheets of the black (haven't used yet), so I'm interested to see responses to this thread.
    As an aside, if you are using this primarily to protect the work, you might try some of those furniture moving sliders. Some come with foam rubber on one side and felt on the other side. I've seen them in 3" and 6" discs.
    Tony
    The optimist says the glass is half full.
    The pessimist says it's half empty.
    I say the glass is twice as big as it needs to be.
    On the clamps I take the oily pads off and use plasti-dip instead. For the mat I switched to LV bench pucks to hold stuff still. For simple protection I just use carpet scraps. Other bench cookies should do as well. Lowes often has the Bench Dog badged version of Rockler's bench cookies on sale. I bought some pad from Peachtree and made my own but, the LV puck rubber is thicker, grips better, etc. Good or bad, these are the kind of thing that you decide on and then use ones that are all the same. Irregular heights of puck/cookies from different makers leads to frustration.
    17,470
    i have seen those pucks glenn but where i use the mat, i like total support rather than on each end or maybe in the middle as well.. but maybe i need to change my methods some
    i like the irwin clamps in easy of quick clamping applications but i had thought of plasti dip..
    13,427
    Didn't some of the "space" balls (for raised panel doors) have some issues like this?
    17,470
    darren, if squeezed to hard, yes. Tom had that problem on some of his doors in his kitchen but the stain and finish took care of it for him in my case i got clear finish and dont need to find out to late it wont hide
    13,427
    Maybe clamp down a test piece of some scrap to get splotched , test finish to see if it will hide?
    30,002
    I sometimes use the black mat material when I'm friction chucking a bowl to finish the bottom, and like you, I've had the oily spots show up. I get rid of them with a few seconds of light sanding with 400 grit paper.
  1. Tread grippers/non slip ideas
    By Jonathan Shively in forum General Woodworking Q&A
    Last Post: 04-20-2016, 12:16 AM
  2. My new Arkansas slip stones have arrived
    By Rob Keeble in forum Carving
    Last Post: 03-11-2016, 08:17 PM
  3. Slip bark whistles - its getting on that time of year again
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 03-30-2015, 11:53 PM
  4. Those touch up slip stones.....
    By fred hargis in forum General Woodturning Q&A
    Last Post: 07-15-2014, 07:04 PM
  5. Old Cat Problem
    By Bill Grumbine in forum Off Topic Discussion
    Last Post: 09-20-2007, 03:28 AM
