Results 1 to 10 of 13
Thread: What to do?
    3,132
    What to do?
    I have this natural edge maple bowl i'm working on.I thought it was dry enough not to warp,Wrong. Well the biggest thing is it woun't sit stright, and the bottom is so thin i can't sand the scratches out as it's way to thin. When i say thin i'm talking about 128th of a inch thin. As the pics show i didn't make a funnel, but if i sand any more i'll go through the bottom. If i'm not carefull i might go through just putting it on my knee to sand the outside. Have the inside sanded to 400, so that will work there. Would really hate to not be able to finish this as i think it's looking good. I have the bowl right at 3/16 (except for that darn bottom) and all the bark has stayed on to this point. What would ya think about adding some kind of beaded foot, maybe the color of the bark, or something there abouts? Thinking about taking a piece of paper and making a temp plate of the circle in the bottom and glueing it in there and then finishing it off. Any other ideas you can send my way would be great.Click image for larger version.
Name:	001 (800x560).jpg
ID:	74670Click image for larger version.
Name:	003 (800x583).jpg
ID:	74671Click image for larger version.
Name:	005 (800x526).jpg
ID:	74672Click image for larger version.
Name:	006 (800x397).jpg
    17,472
    steve i think it would look ok with a contrasting base, but when you sand it out wont you be taking a chance of going threw in the bowl its self?
    3,132
    Larry what i'm thinking is to fill that whole circle with a piece of wood about 3/8 of a inch and then carve a bead in just the outer edge of that 3/8 piece leaving about 1/8 on the inside of the circle and the full 3/8 on the bead. hope that makes since.
    30,014
    Personally, I don't like contrasting bases on most pieces, especially on a NE bowl. I'd say finish it as-is (finish sanding the outside to the extent possible) and let the bowl rock. It's not like you're gonna be serving soup in it...it's a decorative bowl. It's going to spend 99.9% of its life on a shelf or table. Why should a bit of rocking matter?
    That's my .
    3,132
    Vaughn i thought about that, but i can't sand out all the scratch marks in the inside of the circle without going through. And i woun't want to even give some thing away that hasn't been sanded right.
    Aug 2008
    Reno, Nv
    3,632
    This is a reach...trust me. What about spraying a bit of water to raise the grain, 1000g wet/dry and see what happens? Like I said...a reach!!
    3,132
    That's possable, but this is thinner than a piece of printer paper. It's a real wounder i hadn't gone through.
    17,472
    well then dont give it away and why did you take it so thin?
    30,014
    ...why did you take it so thin?
    That's like asking me why I'm so doggone good-looking. Sometimes things just happen.
    3,132
    Well i really didn't mean to get it that thin. I had a little beaded ft on this piece, but when it warped it really looked bad and it rocked a lot. more than it does now. I thought i could get it to sit right by sanding that foot off, and i ended up sanding the center also, for some reason.
