Results 1 to 9 of 9
Thread: What can this thing be used for????
    2,784
    Ok, not sure if this is the best place for this question, but it is definately a fixture! I got this at work that came out of a utility van, didn't get to see how it was mounted to know what it might have been used for, but doesn't appear to have any wear and tear on it. Check out these pictures, one from each side of this contraption.1)right side Click image for larger version.
ID:	6527 2)left side Click image for larger version.
ID:	6528 3)front Click image for larger version.
    4)back Click image for larger version.
    My first thought was to mount my scroll saw on it so I could tilt it to different angles when I needed or wanted to. What do you think? Thanks for looking and offering ideas! Jim.
    edit: I guess I should also say that this thing is about 9" tall, and 5" wide. The adjusters have numbered dials on them that you can rotate to zero out, and the side adjuster has elevation marks from 20 to 66 in 1 degree slashes stamped on the metal sides.
    Coolmeadow Setters...
    Exclusively Irish!
    810
    It looks like a setup jig for a (small) satellite dish installation crew??
    3,147
    Quote Originally Posted by John Bartley View Post
    Ya I imagine the crew were only about 12" tall.
    15,816
    Yep, that is a disk mount for sure, what you can use it for......?
    Dunno, but worth hanging on to!
    WNY, Buffalo Area
    873
    Jim,
    I used to work for a company that did tech support for the Sony Satellite boxes and dishes. A dish mounting bracket was the first thing that came to mind when I saw this.
    I know that the brackets are pretty strong....just make sure that what every you mount it to is very secure. One of the guys that I worked with did pullups on one of the dish arms that was on our building. He was about 190 lbs.
    www.tinyurl.com/thewoodshoppe
    Northville, MI
    507
    Spud cannon.
    Jim
    WNY, Buffalo Area
    873
    The graduations on it should allow you to get you Tater Gun right on target!
    30,237
    A very accurate flag pole holder?
    810
    Hehehe ... I had to read it a few times to see where I'd made my grammatical "oops" - nice catch
  1. What is that thing ?
    Last Post: 04-07-2010, 07:18 PM
  2. Some thing different
    By Chuck Thoits in forum Lathe Project Showcase
    Last Post: 03-18-2010, 07:39 PM
  3. Another DNA thing
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 01-19-2009, 04:04 PM
  4. The whole DNA thing?
    By Paul Downes in forum General Woodturning Q&A
    Last Post: 03-14-2008, 05:05 PM
  5. If it's not one thing, it's another! It's always something!
    By Jeff Horton in forum Designs, Plans and Sketches
    Last Post: 03-02-2008, 10:01 PM
