Results 1 to 10 of 21
Thread: Mower Lights
    13,464
    Mower Lights
    When I recently picked up a new zero turn, I was too cheap to pay the $75 + installation for lights on it. So I picked up a small set of driving lights from the local auto parts store for $20.
    The lights will mount in the small openings in front of the platform behind the front suspension.
    I wanted to use some existing holes in the frame gussets.
    I welded these up from some scrap. Sorry no weld pics, phone died last night and wanted to get them primed, so took pics this morning.
    How the light will mount.
    I did buy the factory switch and bezel, just have to pop out the plastic plug in the control panel. The factory light kit diagram shows a place to tie to the key switch for power. I plan to still pull my initial power from there, but will run some relays instead for powering the lights from the batteries directly. This should only draw about 2 amps through the key switch rather than 10 - 15 amps. Also will give me the ability to power additional relays so I could put another light on the rear if need be.
    I also have plans for some other electrical accessories, like an electric spreader that a friend gave me, which I’ll make a quick attach mount on the front of the mower for. The relay panel will be mounted under the seat, so should make it easy access for wiring that and a snow plow if I decide to buy or build one.
    I'm not sure I'll ever mow much in the dark, but at least I'll have them on there.
    TIP: For getting hole placement in an area that is too tight to get your measuring tools into to measure. I cut a piece of paper to the size of the bracket base, then placed it on the gusset where the bracket would mount. I then took a pencil and shaded the paper, which left impressions where the holes were. I then took the paper and laid it on my bracket and center punched where the hole centers were. Finally flipped the paper, placed it on the second bracket and used the previous marks to mark that bracket (I verified they were the same first).
    17,475
    is it my eyes today or are those lights facing the frame which would block any light to your mowing path???
    S E Washington State
    3,777
    Of the three riding mowers I have owned, I have never used the lights. At least the brand you bought makes it an option. I really don't understand why they are not an option on all. Then I would not have had to pay for something I do not use.
    "We the People ......"
    13,464
    It's just the angle of the camera, they are centered in the opening and about as far forward as I can put them without the front suspension smacking into them.
    Quote Originally Posted by Paul Douglass View Post
    I've had to mow a few times after the sun started going down, especially in late fall when it's getting dark earlier.
    5,323
    Will the generator on your mower handle those lights? Most driving lights are 55 watts each, and unless you've got an auxiliary generator (other than the flywheel-mounted one on the engine) they might over-tax the system. The B-S engine mounted generator is generally less than 100 watts.
    BTW, in about ten years of mowing and snowplowing, I've only used the headlights on my tractor once.
    13,464
    I checked that, somewhere I read it was a 15 amp alternator (180 watts), just can't find the link so may have been in the manuals.
    Rochester Hills, MI
    940
    Congratulations!
    You're going to love that ZTR if you've never used one. We got a Gravely ZT 52HD last spring and it's a BEAST, I love that thing! It almost makes mowing the lawn and fall cleanup fun.
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten"
    13,364
    My favorite electric accessory I have for my garden tractor is a 15 gallon tank with an electric pump on it. I use it for spraying down the weeds.
    Which reminds me, I've got a lot of spraying I need to do. The weeds are growing like, well, weeds around here now...
    13,464
    Quote Originally Posted by John Pollman View Post
    Congratulations!
    My first zero turn I ran was a GrassHopper brand, which used roller chains to connect the drive units to the axles. After 80 - 100 hours the chains would get so much slack that it would jerk around violently, even put my back out once due to it.
    I did look at the Zt52HD, it didn't have the ROPS bar (roll over bar system), so was considering the Pro 152, but Ferris has about the same specs as the Pro 152 for about $1000 less.
    yeah, planning to run electrical to front and back of the machine for such an accessory for spraying the driveway. Probably one that has a spray bar option to wide areas quickly, which will be on the back of the machine.
    Dec 2008
    Santa Claus, In
    4,779
    Strange, the way the weather has been in your area, I guessed a plow was first
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
  1. Death by mower ? naaaaa :)
    Last Post: 06-11-2014, 04:12 AM
  2. My new mower
    By Jonathan Shively in forum Off Topic Discussion
    Last Post: 09-01-2013, 06:10 AM
  3. My next mower
    Last Post: 08-03-2013, 01:51 PM
  4. Crazy Mower Restore
    Last Post: 08-06-2010, 08:43 PM
  5. Mower issues
    By Mike Gabbay in forum Off Topic Discussion
    Last Post: 04-05-2008, 01:35 PM
