Winchester .308 Barrel
Les Elm
Red Deer, Alberta, Canada
With a .308 center band and a .308 for the cap.
Need the center band to prevent the cross refill cap from bottoming out on finial stud
when the refill is retracted.
Cleaned the projectile and casings with Brasso, polished with Fitz, wiped down with lacquer
thinner, plugged .308 casing necks with Play-Doh, plugged projectile nib with bees wax and
applied 4 coats of lacquer using my "Dipping Method".
Les
