Results 1 to 10 of 12
Thread: Cypress Porch Balusters
    Grand Rapids, MI
    383
    Last fall I had a customer come to me in need of 60 spindles for a porch that was in bad shape. The house is in a historical district, and all work/renovation must be "as close to the original as possible". Of course, I love this kind of work, but at the same time I had been dreading the thought of having to deal with 2 perpendicular pommels on a softwood spindle. The due date was set for the end of March, and a few weeks ago it was time to face the music. Fortunately once I got into it I realized it wasn't as problematic as I thought it would be. But I still couldn't make a false move, cuz that dern cypress is unforgiving stuff (there's a few 'oops' spindles in the burn pile).
    - Hutch
    13,454
    Very nice work Hutch! I'd be nervous about turning those as well.
    4,699
    Wow nice job!
    Did you do all of those freehand?
    And if so - any tips/tricks you used to get them so spot on?
    Jul 2007
    DSM, IA
    5,719
    Those look great Hutch, but I think the third one from the right is a bit thicker on top. I can't imagine working thru all those...Well Done!
    My Website
    Dec 2012
    Bedford, NH
    1,683
    They look great. Once you are set up, how long does it take to complete a single spindle? I trust you use a template, so what material do you use for the template to stand up to that volume of work?
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    Goodland, Kansas
    4,834
    Looking good Hutch.
    Bernie W.
    S E Washington State
    3,777
    Now, that right there is some fine talented turning!
    "We the People ......"
    Aug 2008
    Reno, Nv
    3,632
    Nice work Hutch!! In your neck of the woods you have some great job security!
    Good stuff as always,Hutch. I'm sure your customer was/will be pleased.
    No, no no! It's the fifth one from the left, and it's thicker on the bottom.
    Grand Rapids, MI
    383
    Thanks all!
    Ryan - I turned these all freehand. I used a masonite story stick for layout, and three calipers settings to part specific diameters.....pretty typical stuff. Good cutting technique is absolutely imperative, but another key issue for speed and accuracy is order of procedure. If you cut the wrong elements at the wrong time you can give yourself headaches. Also, you have to have control and power while remaining fluid in your movement. Don't white knuckle it or you'll only last a couple hours (and keep your legs and body relaxed too). As for making them identical, your eye naturally makes the given elements look the same after you turn a few. In fact, your eye will even know when you should stop at certain diameters. By the end I probably could have turned one within 1/32" at any point without using calipers. That just sorta happens on its own.....and it's pretty cool.
    Al - No real template per se, just a story stick and calipers. Time it took: From the stack of blanks to completed and off the lathe I got them down to about 8.5 minutes each at my fastest. (I only worked at this pace for a few of the hours.) Under ten was the more typical time.
    As to the variation in thickness, I blame wood movement. I milled them all at the same time, but some of them warped ever so slightly. It's also the lighting. It's the light's fault....that's it.
    - Hutch
  1. Spalted Cypress
    Last Post: 02-04-2014, 10:09 PM
  2. Need Cypress
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 05-12-2010, 06:55 PM
  3. Ash Porch Swing
    By Donald Stonecipher in forum Flatwork Project Showcase
    Last Post: 10-02-2009, 05:58 AM
  4. Porch ceilings
    By Jeff Horton in forum Carpentry and Construction
    Last Post: 08-30-2008, 03:02 PM
  5. Cypress question
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 03-08-2007, 02:30 PM
