Chip Sutherland
- Frisco TX
Here are two recent pieces. Sorry for the pics but that's what you get with an iPhone. I have a great photo tent with graduated background but I have absolutely nowhere to set it up anymore. So I hung an old sheet from the kitchen rack.
First piece - Silver maple from a neighbor's tree that came down in a micro-burst. I guess it spalted a little bit. I started turning this piece the morning of my mother's memorial in Jan. I needed something to occupy my time and get people out of my face. Spinning wood at 1000 RPM makes people keep their distance. All the wood from this tree has been fascinating with wild figure, spalting/staining, etc. I pyro'd the rim lightly because it seemed to need something. The original thought was to do a heavy/dark pyro band. I'm still undecided. Sanded to 800. Finished with mineral oil to limit any coloration. Size 5 1/8w X 1 7/8h on a 1/8 in high foot.
2nd piece - Quilted maple. This is an end cut of a board so there is only a limited amount of figure. This piece was done for my turning club's quarterly challenge last night. However, I should have read the rules because the finished piece is 14 5/8 in diameter and the rules allow 9-11in entries. Although, it is 10.5 in on the short-side...I was DQ'd. Doing a square platter was strictly a whim. I had laid out for a 10.5 in round platter. It is a decent piece. Wish I had used a fourth color. More figure would have made this a prettier piece. I encountered a fair amount of flex in the corner wings right at the transition to the body. As a result, I didn't go as thin as I wanted. Consequently, I can feel a little thickness variation. Sanded to 3200. Finished with Deft Spray-on Semi-gloss lacquer (rattle can). You can see the chatoyance a little better in the last picture which was with the flash turned on. Size: 14 5/8w X 1 7/8h on a 1/8 in high foot.
FYI...Both pieces were finished on the vacuum pump that I posted as a process thread on this forum a few weeks ago. I had to make a smaller vacuum chuck for the bowl. The platter was on the vacuum pump for 2 straight hours while I sanded and finished the bottom. solid 17 in/mg...19 in/mg when I finally finished it.
