Results 1 to 6 of 6
Thread: Spalted Maple & Fiddleback Maple pieces..
    May 2011
    Frisco TX
    42
    Here is crazy spalted/stained piece of silver maple. This is a local maple tree cut down and it spalted in my garage in Tx. I really wanted to do something special with this piece. My daughter was goading me to dye it pink or purple. In the end, I just went with a utilitarian bowl as nothing else seemed to fit. Finished with Mahoney's Walnut oil which I have not used in a long while. It says to cure it under UV lighting so I left it in the chuck and put it in my carving vice. This has 2 coats...destined for 3-4 more. Then after a couple of weeks, I will buff it out.
Name:	IMG_0089 resize.jpg
ID:	74889Click image for larger version.
Name:	IMG_0090 resize.jpg
    Here is a piece of fiddleback maple that I mounted on my vacuum chuck to try it out. Lessons learned: 1) chuck worked great 2) sanding sealer is old or I forgot to stir it well 3) dyes do not have to be applied on a vacuum chuck. They can be applied off lathe dried then remounted for lathe sanding. The specks you see in the bowl bottom (1st pic) are the dye being pulled through by the vacuum but they were blocked by the sealer so they never made it all the way thru. There is really only one way to solve this which would require removing the sanding sealer and dyeing the inside, too. Not worth my time. My daughter loved this piece in her school colors.
Name:	IMG_0094 resize.jpg
ID:	74890Click image for larger version.
Name:	IMG_0095 resize.jpg
ID:	74891Click image for larger version.
Name:	IMG_0097 resize.jpg
    The Maple family of woods are a wonderful canvas for turning. It has only one drawback and that is the end grain marks. Fresh sharp tools and sand paper are my weapons.
    Aug 2008
    Reno, Nv
    3,632
    Amazing Chip!!! But how big are they? JMHO, but I think the foot on the silver maple is a little heavy I like the dye job on the fiddleback...that stuff is so hard to find!!
    May 2011
    Frisco TX
    42
    The spalted one is 8w x 4h...The fiddleback is 7.5w x 2.25h. I stumbled into a Rockler when they had a huge box of fiddleback maple. Most folks were buying based on thickness and size. I bought based on grade. This purple was AAA as are all the other ones in the pic. The store employees raided all the AAAA pieces. The big platter pieces were originally intended for the collection plates I did but I did find enough of them fast enough. Too bad all those folks with 10 and 12 inch lathes didn't want the larger pieces. So (shamelessly) I am stuck with 4 14x3 and 2 13x3 pieces. I guess I will suffer.
Name:	IMG_0100 resize.jpg
    3,132
    Chip good looking bowls and some eally cool wood. Them blanks ain't to shabby ether.
    30,008
    Nicely done, Chip. I really like that purple on fiddleback. I've still got a couple of small blanks of the Rockler fiddleback myself. I wish they would have had some larger ones when I bought mine.
    And I see you learned the "don't apply dye under a vacuum" lesson. I've had some woods (ash, notably) that is so porous that the dye will bleed through even if it's not in the vacuum chuck. This is especially true on thin-walled pieces.
    Goodland, Kansas
    4,834
    Really nice bowls and wood. Color is nice.
    Bernie W.
  1. spalted maple hf
    Last Post: 03-31-2011, 02:56 AM
  2. Spalted Maple
    By Wayne Bower in forum Lathe Project Showcase
    Last Post: 03-29-2011, 11:14 AM
  3. Spalted maple
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 08-18-2009, 01:11 PM
  4. Spalted Maple
    By Mark Pruitt in forum Lathe Project Showcase
    Last Post: 08-21-2008, 02:25 AM
  5. Spalted Maple
    By Richard Smith in forum General Woodturning Q&A
    Last Post: 03-23-2007, 12:51 PM
