Results 1 to 10 of 28
Thread: the $1000 woodworking tool test
    THIS IS NOT A CONTEST... I hope the title isn't misleading... let me know if you think it is.
    This IS a way to get you thinking about what your most important tools are, which will in turn give you some insights into yourself as a woodworker.
    Here's the hypothetical scenario:
    1) You have no tools. Zilch. Zero. Not even a pocket knife.
    2) You have $1000 tool budget for a YEAR.
    How would you spend your $1000?
    Why?
    You may be interested to read how Marc Spagnuolo answered: http://thewoodwhisperer.com/?p=159
    I look forward to hearing how you'd outfit your woodshop with only $1000...
    G
    I'm the editor of ToolCrib.com.
    4,992
    garrett,
    this is simple.......the entire budget would go toward lay-out and hand tools.....i wouldn`t spend a nickel on power tools...that way in a barren shop i could still build and i wouldn`t throw my money away on cheap,make-do type of power tools......tod
    this answer shifted my perspective - thanks Tod.
    Toronto, Ontario, CANADA
    2,332
    garrett,
    With two exceptions I agree with Tod. The two power tools that I would buy would be an electric (not battery) powered drill and a jig saw. They would probably both be Bosch.
    Cheers, Frank
    Rochester
    825
    basic router and a few bits, good used contractor saw with a decent GP or combo blade, a planer w/cutterhead lock and shopmade sled, cordless drill, jigsaw, small used block plane, some HF Pittsburg bar clamps, basic Kreg pocket hole jig, sandpaper, combo square, tape measure. If I go over $1k, I'll think up some justification pretty quick, but I think I could get those items pretty close. . The router is one of the most versatile tools I own. I could build a simple shopmade router table for next to nothing. I use my TS alot and wouldn't want to do without one. The surface can be covered with a $10 piece of hardboard and can double as an assembly table. I'd still want a basic bench of some sort...road finds might dictate what I use. I'd probably want a shop vac in short order too. I'm pretty frugal between garage sales, sales, and road finds, so there'd eventually be a few unlisted jigs, helpers, and misc stuff.
    Got Wood?
    The Heart of Dixie
    4,265
    Tod said what I was thinking. That's the sure fire way to be able to set up and produce something.
    Another way is older used tools. With some careful shopping I could pick up an old tablesaw and a drill press and refurbish them and still have cash left to add some hand tools. I would out hold for the cosmetically ugly and just refurbish and repair them. You can get some real deals that way. I believe I could set up a decent shop on $1000 with some patience and a little luck. And of course a lot of my labor.
    Jeff
    Custom built boats and Kits
    A razor knife
    Straight edge
    string
    Pencil
    Japanese handsaw
    Speed square
    circular saw
    Chisel (s)
    Drill, or bit and brace.
    Rabbet plane.
    sanvik scraper.
    Business cards.
    coping saw.
    Stanley #4 style plane
    Put the left over money in the bank and keep working
    like a mad man till you can get a piece of land and shop space like Tod.
    Per
    I must add that when I was young (er)
    and decided I wanted to build houses.
    I went to work, I kid you not,
    with a hammer a free nail apron, tape measure, knife, and a ball of string.
    But my wages instead of over the bar rail at clancys went
    right back in to my company of the day.
    Per
    New Zealand
    97
    Interesting thought experiment
    Top of my list would have to be a thickness planer, if you are on a budget you aren't going to be getting that expensive pre surfaced wood are you.
    A reasonable router and a set of bits for it.
    A reasonable jigsaw with selection of blades.
    A sander
    Drills, probably a corded one and a cheaper 'screwdriver' size cordless.
    A small toolbox of hand tools, ruler, square, chisels, pencil, hammer, knife, handsaw, sandpaper and some cheap clamps.
    A small bandsaw, if I could fit it in the budget. I could make do with the jigsaw if need be, but I do like my bandsaw.
    Then a good session of jig building to build a workbench, planer sled, router table, router bridge, M&T and dovetail jigs for the router etc.
    Actually I guess I've just basically described what I have in the shed already A table saw and jointer would be nice, but I can live without them. If I get another $1000 to play with I'd go with a chainsaw sawmill. Then my wood is basically free
    Cheers
    Ian
    535
    Speed square....
    A friend of mine calls that the "squammer".
    Handy, and somewhat indestructable.
  1. My message to woodworking tool retailers
    Last Post: 05-30-2015, 09:19 PM
  2. Sort of a Woodworking Tool…. Phtotgraph your work
    By Phil Stivers in forum Classified Ads
    Last Post: 03-12-2014, 03:37 AM
  3. Ever heard of Arduino no no its not a new woodworking tool
    Last Post: 11-27-2013, 03:35 PM
  4. The beginnings of my Fine Woodworking Tool cabinet
    By Rob Keeble in forum Flatwork Project Showcase
    Last Post: 10-28-2013, 06:14 PM
  5. Dumbest use of a woodworking tool.
    By Jesse Cloud in forum General Woodworking Q&A
    Last Post: 03-25-2007, 11:06 AM
