Results 1 to 10 of 11
Thread: DIY Shoulder/Chisel Plane
    13,462
    Anyone made their own using a chisel?
    http://lumberjocks.com/mafe/blog/23524
    I may have to give one a try tomorrow night.
    9,077
    Looks like fun. He states at the end that "this is not a replacement for any tool". I'm not sure what he means by that, it seems to work. LV has a commercial version.
    13,462
    Yeah, not sure about that comment.
    I was noticing he left the chisel overhanging the outside edge, is this normal? I'd think that it's would cause some fraying without having the block to force the wood to shear off.
    9,077
    I'm no hand tool expert but, I overhang a few thou when I want that action. Unsupported overhang beyond that would lead me to poor results but, that's me .
    13,462
    OK, so a little overhang can be desirable. I'm planning to use a 3/4" chisel, will probably cut the base to 3/4" (maybe 23/32) as well so I can use it for cleaning out 3/4" dado's
    10,604
    Maybe you could use an old chisel and cut the blade 3 or 4 inches long. Might be easier to hold and use rather than having the handle of the chisel stick up so high.
    Pretty darn cool though
    13,462
    That was my thought too, to cut it off. A few months back, I really couldn't have foreseen the need for a shoulder plane, but just on this one simple project I'm seeing the light. I figured I might as well give this one a try before dropping the coin for a commercially made one.
    5,323
    ...I figured I might as well give this one a try before dropping the coin for a commercially made one.
    If you do decide to drop the coin, I'd recommend the LV Veritas medium shoulder plane. I have others, but the LV Medium is my 'go to' plane for most tenoning jobs.
    13,462
    Tonight I got one made and it did the job. I need to find a chisel with a longer blade or just order a shoulder plane blade for it. I think I may have the mouth a bit large, but luckily I have plenty of stock to make another or two.
Name:	2013-04-15 20.04.48.jpg
ID:	75118Click image for larger version.
Name:	2013-04-15 20.04.59.jpg
    12,264
    Re: DIY Shoulder/Chisel Plane
    Darren also consider that for many planes both metal and wood their are always blades available that can be bought and used for this application.
    I have this project on my to do list and purchased a piece of European Beech to use to make it. In my view there is good reason why some specific woods were/are used in applications like this. Not all hardwoods are created equal. I think density and perhaps less elasticity as a result means better harder to flex when wedging and harder sole therefore more consistent and secure setting of blade is my thoughts to making the plane a user.
    My guess is the reason for the comment he made would have to relate to how easy it is to setup and get the shaving wanted when in the tight spot.
    Lets just take a normal well made wood plane, it has a relatively easy way to pretty precisely set the blade position simply with a tap in front or rear on the body once the blade is approx set. This allows for fine tune.
    I would think same can be done in this case. Dunno hence i want to make one.
    Perhaps Bill S. will weigh in on his experiences.
    I really like the making of tools, more than actual projects.
    Sent from my MB860 using Tapatalk 2
  1. Flush Plane / Flat Chisel Plane
    By Richard Line in forum Neander Tool Questions and Show & Tell
    Last Post: 10-06-2009, 09:12 AM
  2. Shoulder Plane Update
    By Travis Johnson in forum Handtool Project Showcase
    Last Post: 06-03-2007, 03:55 PM
  3. Self-Made Shoulder Plane
    Last Post: 05-13-2007, 03:57 PM
  4. Record 073 Shoulder Plane
    By Mike Henderson in forum Old Ads
    Last Post: 04-23-2007, 05:28 PM
  5. Sexy Shoulder Plane
    By Ian Gillis in forum Neander Tool Questions and Show & Tell
    Last Post: 01-23-2007, 02:50 AM
