Results 1 to 3 of 3
Thread: butcher block style knife holder style..
    17,477
    i would like to make a holder for some objects that are significant thicker than a knife and am wondering how they make the slots line up for knives in on of those style blocks.
    Dec 2008
    falcon heights, minnesota
    5,610
    my first thought would be that when you are gluing up the block, leave the first one full sized with a shallow dado on the inside side, then on the next blocks make a shallow dado on the table saw about half the thickness of the blades in question, then keep going across, and the last board would be like the first. just the way i would do it. this would have some air flow if the blades happen to go in wet.
    benedictione omnes bene
    www.burroviejowoodworking.com
    5,533
    Larry, the last time I looked into making one of those, iirc the plan called for preparing the block, then cutting off the 'back', as if making a bandsawn box. After you had that cut, you then cut the slots with.a dado stack on the table saw, & glue them back together.
    Or just prep a board the same size as your blank & still cut slots with dado stack etc...
    -Ned
  1. The butcher block project...
    By John Pollman in forum Flatwork Project Showcase
    Last Post: 04-17-2013, 04:47 PM
  2. End Grain Butcher Block For Counters?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 12-23-2012, 08:33 PM
  3. how would you flatten an old butcher block?
    Last Post: 02-17-2007, 02:54 PM
  4. Butcher Block Cutting Board Take II
    By Vaughn McMillan in forum Flatwork Project Showcase
    Last Post: 01-03-2007, 02:48 AM
  5. Butcher Block Oil...............
    By Mark Rios in forum Finishing School
    Last Post: 11-16-2006, 10:01 PM
