It has been awhile since I posted something. This is a solid walnut stand & canopy that I built for a customer of mine. From start to finish. I planed all of the walnut.
The customer wanted it stained dark walnut I used general finishes water base. I sprayed 4 coats of satin enduro- var. I covered the inside with a white laminate the same stuff they use in showers. It very easy to keep clean.
