Results 1 to 10 of 17
Thread: cnc bench
    Dec 2008
    falcon heights, minnesota
    5,610
    cnc bench
    with the temporary nice weather, i decided it was time to get the shop ready for the summer season (if it ever shows up), and get the bench for the cnc machine built. the first 3 pics show the various materials that went into this bench. the next one shows all of the legs with the notches cut. then we have both of the leg assemblies put together, along with the first, then both of the top connecting stretchers. then it's on to the plates for the casters, the casters, and up on its wheels. more pics to follow....
    benedictione omnes bene
    www.burroviejowoodworking.com
    Dec 2008
    5,610
    as promised, here are the rest of the pics. now that it is up on its wheels, its time for the top boards, mdf for the cnc machine to be attached to, and use as a waste board. then we have the dust control shop vac in place, the stand for the laptop that will be running the cnc machine, and a close up of the stand with the laptop in place. while all this was going on, my brother and one of his friends stopped by in his friend's '32 coupe.
    Sacramento, CA
    1,367
    Nice! I love it!
    Forgive the silly question - are you building your own machine or buying?
    Jason Beam
    Sacramento, CA
    13,460
    Turned out nice Dan. Will be nice having all the stuff on one bench like that. You might consider a pull out drawer for your bits and various hold downs you'll end up with.
    Are you planning to use linuxcnc? or another control software?
    Dec 2008
    5,610
    jason - the machine itself is in kit form. the basic work area will be roughly one meter long, by half, to two thirds of a meter wide. the nice thing about this kind of bench, is that it can be adjusted for width, height, and length. i've included some pics that show the variations that i've used for the tools, some taller, some shorter, some wider, and some narrower. all built to suit the need, all with casters that are rated to 300 lbs. with the behemoth, the bench was lengthened, and enclosed on 3 sides, with large drawers underneath, and on the end, with a box for odds and ends.
    darren - it will be using the ubuntu linux environment, with linuxcnc (had to check the laptop on that), with open source code programs to convert sketchup/inkscape files to gcode. i hope to have enough saved up for the actual machine (about $700) by the middle of summer. the only upgrades to the machine will be the longer rails, and a dual drive upgrade for the gantry. one good thing about this bench, is that i will be able to add a small cabinet on the bottom, just to the right of the shop vac.
    Attached Thumbnails Attached Thumbnails behemoth.jpg   new set up bandsaw.JPG   new set up drill press and spindle sander.JPG   new set up mortiser.JPG   new set up shaper.JPG
    Looks good, Dan. The Shapeoko kits look very cool. Wish I had a place (and the money) for one myself.
    9,077
    How fun. Looks like a great project Dan. Keep us posted as you go.
    new york city burbs
    10,188
    dan, what kind of projects do you have lined up or believe you will be doing with that?
    do you have any specific income generating ideas lined up?
    Human Test Dummy
    Dec 2008
    5,610
    i was thinking signs and such. it will also be useful for making smaller parts for other projects.
    Dec 2008
    5,610
    been a while, but back to it again. after giving it some consideration, i decided to go with the vacuum method for holding work parts down, as the primary method. the pics show the layout and build of the vacuum box. i will be hooking it up to my dust collector (such a hard working machine). the dust collector moves air from a slightly over 25 cu ft area, at the rate of 650 cu ft/min. for the first test i used a fairish (7x12) bit of mdf. slid around quite nicely with no vacuum, but with the vacuum applied, it was quite a bit more difficult to move. i think that with the sides sealed with a coat of shellac, and fashionable duct tape trim around the seams, it should eliminate any of the vacuum lost from the sides. after the first test, i think i will remove the lower bag to keep a good airflow going. i also moved the laptop pedestal over to the left some more, to accommodate the trackball. also, pop found out about the cnc machine tonight, he was a bit grumpy until i mentioned to him that the bench had been there for the last 6 months, and showing him how it will work. he said it was all voodoo to him. he's not exactly computer friendly.
    Attached Thumbnails Attached Thumbnails 017 first side of vacuum hold down in place.jpg   018 ends and supports.jpg   019 fitting for vacuum.jpg   020 end with fitting in place.jpg   021 other side glued down.jpg
  1. First Bench
    By Ken Cook in forum Flatwork Project Showcase
    Last Post: 01-02-2015, 06:17 AM
  2. New (for me) RAS going in the bench
    By Robert Horky in forum Carpentry and Construction
    Last Post: 10-09-2012, 10:47 PM
  3. New Orleans Saints Bench { Final Bench }
    By Marshall Border in forum Flatwork Project Showcase
    Last Post: 03-30-2012, 02:23 PM
  4. Repurposed bench materials - dedicated sharpening bench
    By Darren Wright in forum Carpentry and Construction
    Last Post: 12-31-2010, 05:25 PM
  5. Bench Dog
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 10-28-2008, 11:18 PM
