Results 1 to 7 of 7
Thread: Knurl on Wood?
    Dec 2012
    Bedford, NH
    1,683
    Knurl on Wood?
    Just a question out of curiosity. Does/has anyone knurl their turnings? I'm thinking of a coarse knurl somewhat similar to what might be seen on a metal shaft, not a wide cross-hatch. I would think the wood might crumble while trying to make the knurl impression, but perhaps someone has mastered a technique. Don't know of an application, just curious.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    Dec 2008
    Santa Claus, In
    4,779
    What kind of turning you doing it on? The first way that came to mind is with a checkering tool, like a gunsmith would use on a stock.
    Found this on amazon http://www.amazon.com/DEMBART-CHECKI.../dp/B003A07GMC
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
    Oliver Springs, TN
    1,726
    Here's a link to a texturing tool http://www.woodturnerscatalog.com/p/...Texturing-Tool that you could probably get the knurled pattern with.
    Goodland, Kansas
    4,834
    Bernie W.
    Dec 2012
    Bedford, NH
    1,683
    Thanks Guys, you've answered my questions. I didn't know if "knurling" could be done on wood. Guess it's called "texturing" in the woodworking arena.
    Austin, Texas
    1,448
    I have seen people get a pattern similar to knurling by using a tool on the lathe that chatters - the kind of pattern we usually try to avoid. After being inspired by a demo, I ground a dead chainsaw file to a rounded point, like a scraper, so it was pretty light and prone to chatter. I tried it... it worked, but I didn't consider it THAT decorative, and am not sure I would do it routinely. But it was an interesting game.
    Charlie Plesums, Austin Texas
    Oct 2009
    Harrisburg, NC
    140
    Here are a couple of videos on the Robert Sorby.
    http://www.youtube.com/watch?v=3Fc0tiG2DN0
    http://www.youtube.com/watch?v=gGDtL1LyM_A
    http://www.youtube.com/watch?v=NTKLkJorTYE
    As shown, the mm of the cutter must be matched to the hardness of the wood or you just wind up with pulp.
    Sorby also makes a chatter tool, which is completely different, for endgain.
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. Thomas Jefferson
  1. Wood Filler vs. Wood Putty
    Last Post: 05-20-2015, 08:07 AM
  2. Knurl GT
    Last Post: 04-14-2015, 09:27 PM
  3. Replies: 12
    Last Post: 02-08-2011, 11:36 PM
  4. Wood glorious wood .....( from the movie of Oliver Twist)
    Last Post: 11-09-2009, 10:30 PM
  5. wood screen door build - which wood should i use?
    By Mike Gager in forum Carpentry and Construction
    Last Post: 03-07-2009, 02:24 AM
