Results 1 to 8 of 8
Thread: My first 3D carving on the CNC
    Sacramento, CA
    1,367
    This weekend turned out to be pretty fun...
    I've been testing some software a guy's writing to work with height maps and generates g-code to carve out 3D stuff... Yesterday was the first time I got to try it (and my first 3D cutting ever!)
    Check it out:
    Jason Beam
    Sacramento, CA
    13,437
    I'm really looking forward to doing some 3d stuff on mine. Need to figure out a good software for drawing my own. Does the phlatscript plugin do 3d contour exports?
    Sacramento, CA
    1,367
    Not that i've seen - tho, i kinda gave up on phlatscript a long time ago and it may have been updated.
    This was just a photoshop file, turned to grayscale and tweaked a little to get a height map out of it then run through this "pre alpha" software to test. He'll be releasing it fairly cheaply (like around $50 or so) - and will be looking for beta testers
    Jason Beam
    Sacramento, CA
    13,357
    Now that's cool. Can you share the image you used? Just thought it would be interesting to help understand some of the issues you had.
    13,437
    Wouldn't mind giving it a try if he is at some point.
    I came across a program called AccuTrans 3D that looks to do a pretty good job of converting files to various formats. Can export the Collada (*.dae) files from Sketchup, open them with AccuTrans 3D and export to other types. Currently I'm testing it with CamBam. Other than having to re-scale the objects to the original size and change the X axis 90 degrees in CamBam, seems to work well for creating 3d profiles.
    The AccuTrans 3D has a 30 day trial, but seems to be "honor ware", but is only $20 to get rid of the nag screen.
    Sacramento, CA
    1,367
    Brent - i sure can ...
    It's a slightly simplified version of my logo i designed like 15 years ago ...
    Jason Beam
    Sacramento, CA
    4,698
    The curves are impressively smooth on the finish cut, I was expecting to see a lot more side-side roughness. I really don't need to watch these they make me want a CnC machine
    13,357
    That helps a lot. I can definitely see what you were talking about in a couple of areas.
    Thanks!
    Quote Originally Posted by Jason Beam View Post
  1. New to carving
    By Dennis Stevens in forum Carving
    Last Post: 02-18-2016, 05:38 PM
  2. Replies: 4
    Last Post: 05-28-2015, 05:41 PM
  3. carving
    By Dave Hawksford in forum Carpentry and Construction
    Last Post: 09-25-2009, 01:34 PM
  4. Some Notes on Carving Tools for "Carving for Turning"
    By Mike Henderson in forum Lathe Project Showcase
    Last Post: 05-02-2008, 07:29 PM
  5. First Carving!
    By Ed Nelson in forum Flatwork Project Showcase
    Last Post: 10-01-2007, 05:39 AM
