Results 1 to 6 of 6
Thread: Cope and Stick joint
    Other than depleting my bank account buying a router bit set to make Cope and Stick joints is there another way to make them.
    DKT
    Are you just after rail and stile contruction or is there a certain look you want? T&G can be done on the tablesaw. Roman ogee pretty much requires a profiled cutter.
    new york city burbs
    10,188
    or if you have a slotting bit, you can make the TG joints using that bit.
    Human Test Dummy
    May 2011
    Cape Cod, Ma.
    1,553
    if you have a moulding head for your table saw you can buy the cutters for about 18 bucks a set. Check out corob they make them for the delta as well. then all you need to do is set up a jig to run your stock over it.
    http://corobcutters.com/
    Quote Originally Posted by Rich Soby View Post
    if you have a moulding head for your table saw......
    I had one of those moulding heads for the TS back in the 70s, it scared the daylights out of me and I got rid of it. But thanks for your reply. Also I was looking for a Cope and Stick design, not a plain slotting bit. I'm resigned to use router bits and miter joints.
    DKT
    May 2011
    Cape Cod, Ma.
    1,553
    lol yeah the ones from the seventies only used screw pressure, knives would go a flyin' if you didnt have them set properly. the set screw on the new ones passes through the cutter thus fixing it in place. (on a side note, you will also need a dedicated zero clearance insert, the dado insert is too narrow in width and too long in length for the cutter)
    mitered doors are nice but alot more work.
  1. peel and stick veneer?
    Last Post: 02-17-2014, 06:47 PM
  2. dogs get the short end of the stick
    Last Post: 01-24-2013, 03:57 AM
  3. HF on a stick?
    Last Post: 12-11-2011, 02:31 PM
  4. Benchdog push stick
    By Bryan Cowing in forum New Tools
    Last Post: 04-24-2008, 05:37 PM
  5. I guess it's gonna Stick
    By Norman Hitt in forum Off Topic Discussion
    Last Post: 04-02-2007, 02:42 PM
