Results 1 to 6 of 6
Thread: Latest work in progress. Upper mantle addition for a flatscreen tv
    May 2011
    Cape Cod, Ma.
    1,553
    just finished assembly last night, time for finish.
    I made it so that the bottom rail/bottom of enclosure will be removable so that the release clips on the wall bracket will be accessed easier. It will be secured in place with 2 small brackets.
    Dec 2008
    falcon heights, minnesota
    5,610
    cool!
    benedictione omnes bene
    www.burroviejowoodworking.com
    13,460
    So will the release clips allow you to remove part to run wiring and such? Looks nice btw.
    Looks real nice, Rich. One of these days I really need to replace our mantle, but that project always seems to get kicked down the priority list for some reason or another.
    17,475
    nice work rich,, sure will dress up the ugly wall that was there
    May 2011
    Cape Cod, Ma.
    1,553
    Thanks guys. actually Darren the bottom rail coming out is only to allow access up behind the tv to compress the release clips. If it was fixed, even with the tv tilted back it would be too tight to be able to reach up behind and take it off. as far as cables and electrical those will be cut into the back once its installed.
    now I just need to get the stain right, the finish on the original mantle is minwax poly with the stain mixed in in a pecan shade. it has been there for several years so of course the wood has darkened as well. Now I have this nice new freshly sanded pine top and the pecan poly finish is very very light and I will have to darken it up. I cant use one of Daves concoctions because the carcase is plywood and Im concerned with the veneer lifting. I took a close up pic and will have to play with some colors to try and match it....
  1. work in progress
    By tom cullom jr in forum Shop Tours
    Last Post: 02-10-2008, 04:51 AM
  2. A Work In Progress
    By Robert Farmer in forum Shop Tours
    Last Post: 08-03-2007, 06:52 PM
  3. latest addition
    By Brent Grooms in forum Flatwork Project Showcase
    Last Post: 04-04-2007, 10:21 PM
  4. Work in progress?
    By Matt Dunlap in forum Shop Tours
    Last Post: 03-05-2007, 02:17 AM
  5. a work in progress
    By ken werner in forum Flatwork Project Showcase
    Last Post: 12-28-2006, 10:40 PM
