Results 1 to 5 of 5
Thread: Small pieces- sprayed
    17,470
    Well i had some trouble in the past holding small pieces in place while trying to spray them, so when i needed to do some edge banding i came up with this plan to hold them still so i dint loose them while trying to spray them.. i just use a pin nailer and anchored them in the very out side edge and will trim off later after the finish is applied.. worked well so maybe others can get some benefit of this trick i have found useful
Name:	small peices 001.jpg
ID:	75607Click image for larger version.
Name:	small peices 002.jpg
    13,437
    Nice solution.
    Great tip Larry. I've also used double stick tape for this for things like pulls that won't take a pin.
    17,470
    i thought about tape but the lacquer might have been more than the adhesive wanted but on a flatter piece i can see that working well glenn.
    Thomasville, GA
    5,992
    Lookin' good, pardner!!!
    Bill Arnold
  1. Cutting small &narrow pieces on table saw
    Last Post: 04-04-2008, 04:52 PM
  2. Cutting very small pieces on TS
    Last Post: 02-04-2008, 02:26 PM
  3. DP - Holding small pieces
    Last Post: 01-14-2008, 09:59 PM
  4. Replies: 8
    Last Post: 12-23-2007, 06:48 AM
  5. Getting small pieces of Corian
    By Aaron Beaver in forum General Woodworking Q&A
    Last Post: 07-08-2007, 04:30 PM
