Results 1 to 4 of 4
Thread: 30-06 Stylus
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    30-06 Stylus
    Be interesting to see how these sell this weekend at the Clairesholm Gun Show.
    Drilled out primer hole to 7mm, installed 7mm tube, cleaned, polished applied 4 coats of lacquer, installed 7mm finial and clip and installed 7mm Stylus.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    Aug 2008
    Reno, Nv
    3,632
    Those should do well Les! Did you have any problem with the offset from the clip to the barrel wall...looks like a close call.
    Goodland, Kansas
    4,834
    Wow that is nice Les. Those should do well.
    Bernie W.
    Apr 2009
    1,083
    Quote Originally Posted by Jim Burr View Post
    No Problem, lots of offset.
    Les
  1. 30.06 Stylus Pocket Pen
    Last Post: 09-13-2013, 04:50 PM
  2. Three pens and a stylus
    By John Daugherty in forum Lathe Project Showcase
    Last Post: 01-02-2012, 01:02 PM
  3. Couple More Stylus's Made Today
    By James Lord in forum Lathe Project Showcase
    Last Post: 01-01-2012, 03:04 PM
  4. Stylus's for the family
    Last Post: 12-25-2011, 04:17 PM
