Results 1 to 10 of 11
Thread: Epoxy bar top care and repair
    North West Indiana
    6,098
    I bought a slab off of Larry a while back to make a bar top out of. Am planning on the two part epoxy glass finish coating. Like this: http://www.youtube.com/watch?v=0jUVdOle4S0
    Before I do this though, is this finish hard to care for? How are scratches taken care of? General care? Anyone with experience I would gladly like to hear from you.
    Thanks in advance, Jon
    Jon
    17,471
    jon, i have never used it but have seen it in restaurants and we know the abuse they get..so i would say it should stand up well i your home.. as for scratches once it is on i would say you could sand and buff out like a normal finish.
    North West Indiana
    6,098
    Thanks Larry, I do like the look but didn't want it to get marred then not able to do anything about it. Guess I'll have to buy a buffer.
    Jon
    17,471
    do a search for care of that type of finish and see if you get some info.. as for buffer, i dont think you would need a buffer use a ROS and some scotch bright pads in the white color or gray to get ti closse maybe micro abrasive sheets would work too like you use on the pens..
    NH
    4,005
    There is no way to sand buff and get it as shinny as it sets up to.
    Let me change that to I have not found a way to yet.
    Stupid hurts.
    North West Indiana
    6,098
    Do you have some care secrets Chuck? This is going on a bar between the kitchen and dining room, want it shiny but don't want something that is going to look horrible soon from normal use. Are there other options that are more durable?
    Jon
    5,320
    I've never used the epoxy, but here's my opinion of tabletop finishes:
    Don't use anything you can't repair. Epoxy will require complete removal - it can't be 'patched.' Ditto with polyurethane.
    Use a high end varnish, like Behlens 'Rock Hard' tabletop finish, that can be repaired without total removal. I've not used that particular product on a counter, but I've done several tables with it, and they all look good after years of service, and with 'reasonable' care.
    NH
    4,005
    Gonna have to say +1 on that Jim
    But you would not have to remover the epoxy. You would have to sand out the damaged area than scuff the whole surface and recoat the whole thing.
    Stupid hurts.
    17,471
    i agree on a "Use a high end varnish" i have also used that kind ofproduct instead of the pour on type and it has held up well for many years.. and it can be built up to a glass finish..
    Mar 2010
    SW MN
    34
    Check with Jamestown Distributors-- they are premier source for West System epoxy. Along with product availability they willingly offer technical advice. They also have available a book "The Epoxy Book"----everything you might want to know about bar top epoxy finish. INMHO nothing beats epoxy.
  1. Epoxy question
    By Charlie Plesums in forum General Woodworking Q&A
    Last Post: 03-11-2015, 04:34 PM
  2. Need some epoxy recommendations
    By Tom Baugues in forum Off Topic Discussion
    Last Post: 10-09-2014, 02:23 AM
  3. Just because I care
    Last Post: 10-07-2014, 04:07 AM
  4. what epoxy?
    Last Post: 06-02-2010, 05:21 PM
  5. Injected Epoxy?
    By Joseph Shaul in forum General Woodworking Q&A
    Last Post: 04-12-2010, 08:32 PM
