Results 1 to 10 of 10
Thread: Drying Green Wood Using Plastic Wrap?
    Jun 2012
    Laurinburg NC
    316
    Has anyone used any plastic wrap and covered the green wood in a drying process??? How to ??? Effectiive???
    30,014
    In my experience, plastic wrap (or bags) accelerates the mold-growing process. And not the good, "spalted wood" kind of mold. More like the "black fungus that looks like it could kill you" kind of mold.
    I do know some guys (including me) have used plastic stretch wrap to cover part of the outside of a bowl after it has been rough turned, but in those cases the inside is still exposed to air...the plastic just slows the outside drying a bit.
    May 2009
    sydney australia
    149
    Plastic won't really assist with drying as its generally water proof
    If its a rough out I coat it with BLO then place in a cardboard box or paper sack with the open end facing down
    Aug 2008
    Reno, Nv
    3,632
    I use it all the time...just poke some holes in it (not a million...just several dozen...depending on the blank size) this way the moisture can get out in a small way. Mold does happen, but plastic is cheaper!
    Spokane, WA
    60
    Reed Gray aka Robo Hippy on other forums uses shrink wrap to cover the outside of his turn green to finish bowls, says it really cuts down on the cracking of the madrone he typically turns.
    Dan
    "A dog teaches a boy fidelity, perseverance, and to turn around three times before lying down."
    Robert Benchley
    30,014
    Quote Originally Posted by Dan Forman View Post
    Dan
    Hey Dan, good to see you. If I recall correctly, I think Reed just wraps the top few inches of the rim with plastic and leaves the lower part of the bowl unwrapped. Is that how you understand it, too? I've done mesquite that way and had good results, but this was pretty stable wood that didn't move a lot anyway.
    Spokane, WA
    60
    Hey Vaughn, I guess I don't remember that part, I think he does go up over the rim so that at least the outside edge of the rim is covered, but not sure about the bottom.
    It's been so long since i've posted here, I had forgotten what my icon looked like! Kind of frightening really.
    Edit: Guess you are right, he just wraps the rim, with about an inch above to cover the outside edge.
    Dan
    Robert Benchley
    30,014
    ...It's been so long since i've posted here, I had forgotten what my icon looked like! Kind of frightening really. ...
    One of the best forum avatars in the history of ever.
    Jun 2007
    4,944
    I really like your avatar. I got a good chuckle out of it!!!
    Anyone who would have an avatar like that, just has to be a good person and fun to be with.
    Enjoy,
    JimB
    VOTING MEMBER
    Spokane, WA
    60
    Thanks guys, it was fun to shoot. Hard to take oneself too seriously in a getup like that. Too bad I can't wear it to work.
    Dan
    Robert Benchley
  1. New wood stash and drying wood
    By Dave Black in forum General Woodworking Q&A
    Last Post: 10-25-2010, 09:53 PM
  2. New wood stash and drying wood
    By Dave Black in forum Shop Tours
    Last Post: 09-24-2010, 05:43 PM
  3. Wood Drying Kiln
    Last Post: 12-18-2008, 03:11 AM
  4. Green wood
    By curtis tolbert in forum General Woodturning Q&A
    Last Post: 06-14-2008, 06:26 PM
  5. drying wood in wax
    Last Post: 03-22-2007, 03:32 AM
