Results 1 to 6 of 6
Thread: Shellac - sanding between coats?
    Feb 2012
    2,749
    I'm just finishing up a little project that I have stained and am coating with shellac. Should I/need I sand or use steel wool between coats? First coat is just on, I'll be back to it tomorrow.
    TIA
    Cheers,
    Roger
    Independence, Kentucky
    1,355
    No need to sand between coats of shellac Rodger it burns in like lacquer to the previous coat.
    17,475
    if you sand it ,, only after the second coat to flatten the nibs you have and then the third coat should be baby bottom smooth
    Like Larry, I sand gently (with 400 grit) to get any nibs but, Charles is quite correct, the coats fully "burn in". I should qualify my sanding statement in that the coat after sanding with 400 is very thin, too thin to allow any ridges to build and thin enough to be nearly dry before I even finish. Almost like putting on a coat of wax. I'll also add that I sand after about 30 minutes without issue. This will vary with your climate.
    Feb 2012
    2,749
    Thanks, guys! I have two coats on now, and tomorrow I'll rub gently with 0000 steel wool (Don't have any 400 sandpaper) and declare it finished.
    Cheers,
    Roger
    17,475
    if your gonna rub it with steel wool use a lubricant ,some wax or soapy water
  1. Shellac or varnish?
    By Roger Tulk in forum Finishing School
    Last Post: 07-08-2014, 10:59 PM
  2. Getting the Red Out - Color Coats Are Done
    Last Post: 06-06-2013, 08:00 PM
  3. shellac
    By Rex Bloem in forum Finishing School
    Last Post: 03-17-2011, 03:12 AM
  4. Salad bowl finish - multiple coats
    By Chris Hatfield in forum Finishing School
    Last Post: 10-16-2010, 10:47 PM
  5. What's up with my shellac?
    By M Toupin in forum Finishing School
    Last Post: 07-28-2007, 04:21 AM
