Results 1 to 4 of 4
Thread: Spalted Green Acacia with Mesquite Collar
    Nov 2010
    Sandia Park, NM
    98
    This is the first project I've had time for in quite a while. Had 3 weeks off from night school and between work and doing landscaping for the Finance Minister, time has been short. This is a piece of Green Acacia I got from Jerry Marcental when I bought the chuck plate from him. The top was a bit too far gone, so I made a Mesquite insert. In hindsight, walnut would probably have been a better color choice, but there it is. I figured as long as I was doing an insert, I could make the hole small enough to keep the fat fingers of other turners out of my form . I feel a nice finial would finish this form off nicely. I haven't turned one in a long time and mesquite was a bad choice for finial wood. I couldn't get it to take fine detail. Regardless, the finial is too short and fat and I don't like the transition out of the top of the form. Finish is AO form is about 8" in diameter. Thanks for looking, candid criticism appreciated.
Name:	Acacia Finial 01.jpg
ID:	75808Click image for larger version.
Name:	Acacia Front 01.jpg
ID:	75809Click image for larger version.
Name:	Acacia Side 01.jpg
    3,132
    Nate as far as the form it self i think it turned out great. I do agree that the finial needs to be taller, and thinner. Also i like the collar to have a slight rise at the opening. Glad to see you getting some shop time finally.
    Nov 2010
    Sandia Park, NM
    98
    Thanks Steve, I agree on the up turned opening. This is the second collared form I've tried and missed the thickness needed to do that and maintain the curve. I was relying on the finial to provide that lift and missed it there too.
    30,002
    About the only critique I have is things you already mentioned. Like Steve said, you nailed the form of the vessel, but I think things kind of fell short on the insert and finial. Is the collar glued on? Have you considered a do-over?
  1. Green and Green square plugs
    By Charles Hans in forum General Woodworking Q&A
    Last Post: 02-01-2013, 12:40 AM
  2. dog collar pen.
    Last Post: 05-05-2009, 11:28 PM
  3. Acacia Vase
    By Barry Richardson in forum Lathe Project Showcase
    Last Post: 05-01-2009, 04:16 PM
  4. Vase w/collar a 1st
    By Jon Lanier in forum Lathe Project Showcase
    Last Post: 10-15-2008, 02:59 AM
  5. Acacia?
    By Steve Ash in forum General Woodworking Q&A
    Last Post: 03-27-2008, 02:34 PM
