Need a quick zero clearance in a pinch? Take a scrap piece of veneer ply, set your ts fence to the cut you.have to make and then clamp the piece of ply to the top tight to the fence. The ply obviously has to be wide and deep enough to support the stock being cut. Once clamped down just run the blade up through and voila instant zero clearance in a pinch!
