Results 1 to 10 of 19
Thread: SketchUp 2013 Is Out
    SE Minnesota
    2,526
    The new version of SketchUp has been released. Check it out here. Download SketchUp 2013 Make if you want the free version.
    Most of the changes are under the hood but there's some cool stuff like easier plugin installation and customize-able toolbars. All the details are on the SketchUp site.
    Dec 2008
    falcon heights, minnesota
    5,610
    dave, i downloaded the free version of 2013, and it says that it is only a trial version that has an 8 hour time limit. what gives?
    benedictione omnes bene
    www.burroviejowoodworking.com
    SE Minnesota
    2,526
    You get an 8 hour trial period of the free version. After that you'll switch to the free version, called SketchUp 2013 Make, if you don't buy the license. Since you've got the pro version for 8 hours of running time you should look at LayOut, Maybe Style Builder if you're interested in that. Try out the Solid Tools, import or export some CAD files and so on.
    13,363
    I did not know about the trial period. That's some good info. I'm going to hold off on it until I'm really ready to try the layout functionality.
    SE Minnesota
    2,526
    Not a bad idea, Brent.
    Dec 2008
    5,610
    thanks for the info dave, had me a little worried there.... lol
    SE Minnesota
    2,526
    No worries.
    One thing you'll find with the new version is that if you set up toolbars to run down the left side, you'll only be able to get them to display as a single column. This is due to the way they had to create the toolbars so they wouldn't get scrambled as they do once in awhile in SU8 and earlier versions. I'm used to having two columns so I made two custom toolbars I could put next to each other like this.
    I just took the tools off the original bars and put them on alternate custom toolbars to get essentially the same layout as the old tools have.
    SE Minnesota
    2,526
    There's a list of some of the new things in SketchUp 2013 and LayOut 2013 to check out. Most of the improvements have been performance related and probably won't be noticeable at first glance.
    I'm going to try the new version when I have a bit of time. I'm still having mouse problems with SU8, and I'm hoping the problem goes away with the new version. It's not like I'm using an oddball mouse or anything...a Logitech M305 with Logitech drivers. The stock MS drivers produced the same problems, namely that the middle/wheel mouse button does not do anything.
    SE Minnesota
    2,526
    Vaughn, you probably need to go in and reassign the function of the CMB.
    I've used several Logitech mice but never installed the driver and they've always worked perfectly. The mouse drivers have historically been problematic because they change the assignment of the CMB away from that which is native to the basic PC mouse setup.
  1. Paddles 2013
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 09-18-2013, 01:23 AM
  2. WIA October 2013
    Last Post: 07-11-2013, 02:45 AM
  3. Lessons from BW 2013
    Last Post: 07-08-2013, 05:15 PM
  4. SketchUp 2013 Zoom Issue
    By Bill Arnold in forum Off Topic Discussion
    Last Post: 07-07-2013, 06:30 PM
  5. 2013
    By Ken Fitzgerald in forum Off Topic Discussion
    Last Post: 01-01-2013, 09:58 PM
