Results 1 to 5 of 5
Thread: Jet 1642 Quill Assembly ?
    Jun 2012
    Laurinburg NC
    316
    I noticed lately if I back the screw out that tightens the quill assembly that my quill assembly will turn some. I know that screw rides in slot like a key way and I guess that is normal if you back it out too far out of the slot? Am I seeing this right? Its not spinning around or anything like that. Just as soon as I make sure the screw is in some it cant turn.
    I do think is ok but just have never noticed it..
    Goodland, Kansas
    4,834
    My jet 1220 does the same thing. So I just have to be aware of it. That is normal according to Jet so if you have to work on the quill it will come out.
    Bernie W.
    Orem, Utah
    935
    What a coincidence. I was looking at some years-old posts on another forum today, one of which was about this very issue - although on a Delta Midi model. The owner removed the locking screw and found that its tip had been rounded over with constant use. After he flattened it on his belt sander, it locked the quill as well as ever. I don't know how similar the two lathes are, but perhaps it's worth a look?
    Aug 2008
    Reno, Nv
    3,632
    My 1642 does the same thing. I just don't loosen the screw that much...just enough for the quill to move freely.
    Tellico Plains, Tennessee
    4,352
    I have a 5 year old 1442 that does the same thing... if I loosen the quill lock handle, the quill spindle will rock in the slot just slightly... when I tighten the lock it stops....
    Chuck
    Tellico Plains, TN
  1. jet 1642 bearings
    By Larry Matchett in forum General Woodturning Q&A
    Last Post: 04-08-2014, 03:09 AM
  2. Fixing quill slop (delta 17-959l)
    Last Post: 07-29-2013, 03:44 AM
  3. sell 1642 for 3520?
    By Dennis Kranz in forum General Woodturning Q&A
    Last Post: 04-28-2010, 02:57 PM
  4. Jet 1642 Lathe at Amazon
    By Rich Aldrich in forum Hot Deals
    Last Post: 02-05-2010, 01:51 AM
  5. jet 1642 lathes
    By Clark O'Neill in forum Hot Deals
    Last Post: 11-28-2007, 07:21 PM
