Results 1 to 8 of 8
Thread: Larger Container for DNA Bath ?
    Jun 2012
    Laurinburg NC
    316
    On a Dna bath for pieces bigger than will fit in the 5 gal bucket what do you guys use that is air tight?
    May 2009
    Lafayette, Indiana
    2,380
    Mike, try using a storage tub. You might have to put plastic over the tub before placing on the lid but you can get storage tubs in very large sizes.
    Goodland, Kansas
    4,834
    I bought something similar to this. I didn't buy six as they are advertising. Big enough for what I need and I put some thin foam with sticky on one side like you use to insulate a door with. I just add fresh DNA every now and then when I see it going down. I started with 3 gallons of DNA.
    Bernie W.
    Jul 2007
    DSM, IA
    5,719
    I think I remember my dad using a large contractor waste bag before. He just made a mound out of lathe curlies, made kind of a pit to place the bag with the roughed bowl in and then he added the DNA to create a little pool like thing.
    My Website
    30,014
    I've used a large plastic tub with a plywood lid I turned to fit. I put weatherstripping on the edge of the lid, and also added a ball valve to let the air out when I put the lid on. I put a quick-connect fitting on it thinking I might want to use my vacuum pump on it, but it seals well without, and I suspect the vacuum pump would crush the tub. Plus, it's probably not a good idea to pull DNA fumes through a vacuum pump.
    I've also done the heavy garbage bag/pile of chips thing for pieces that wouldn't fit in the tub.
    That all said, I pretty much stopped using the DNA bath, since I wasn't convinced I was gaining anything. Pieces that I just wrapped in paper and let dry didn't seem to warp or crack any worse than the DNA-treated pieces, and they seemed to dry in about the same length of time, too.
    Southeast Pa
    2,019
    Now that a fancy DNA container and the color matches the dust collector... What a artist for detail...
    Oct 2011
    Cortland NY
    238
    Ok forgive me on this but what is this for exactly? Never heard of anything like this.
    30,014
    Ed, a lot of turners soak rough-turned green wood pieces in denatured alcohol for 24 hours or so before drying the piece. There is some evidence that it speeds the drying process and reduces the amount of cracking and warping. Dave Smith is considered to be the grandfather of the process:
    http://www.woodcentral.com/cgi-bin/r...cles_473.shtml
  1. Stacking Container
    By Kerry Burton in forum Lathe Project Showcase
    Last Post: 03-08-2009, 08:20 PM
  2. Pecan Lidded Container
    By Shane Starnes in forum Lathe Project Showcase
    Last Post: 08-04-2008, 05:34 AM
  3. Dust free enviroment container (home made cheap)
    Last Post: 10-06-2007, 11:14 PM
  4. A Larger Bowl
    By Barry Richardson in forum Lathe Project Showcase
    Last Post: 06-26-2007, 06:00 PM
  5. Larger nut for a Uni?
    By Mark Rios in forum New Tools
    Last Post: 01-08-2007, 03:32 PM
