Results 1 to 3 of 3
Thread: Respirator Cartridges
    Jun 2012
    Laurinburg NC
    316
    One of the items I use especially when sanding on the lathe is this half mask respirator. It works good and I have good fresh air. The only thing is the price for the filters or screw on cartridges. They are pricey..Also I am not sure how long I should use one before changing them.. I tried the Trend Airshield Pro a while back and because I have some neck issues it wouldnt work for me.
    http://www.benmeadows.com/msa-comfo-...130601083701:s
    Aug 2008
    Reno, Nv
    3,632
    It can be a bit hard to tell Mike. Couple things to think of; using compressed air from the INSIDE of the filter, blow the cartridge out gently. When you get to the point where the exterior stuff no longer blows off...time to toss it! Another thing...always have a new cartridge at hand. Periodically, swap new with old and make note of additional resistance between the two. Notable resistance...time to toss it!
    Hope that helps.
    Nov 2012
    Wapakoneta, OH
    611
    As they clog, they don't loose their filtering ability....it may even improve due to the dust cake. So if you struggle to pull air through the filters, it's obviously time to change. The idea of having a spare set and comparing the 2 is a good one.
  1. Respirator recommendation
    Last Post: 05-19-2012, 12:37 PM
  2. Follow on my search for a respirator
    By Jiggs Elphison in forum Off Topic Discussion
    Last Post: 06-01-2010, 01:17 AM
  3. Respirator
    By Jiggs Elphison in forum General Woodworking Q&A
    Last Post: 05-17-2010, 04:12 AM
  4. Triton Respirator--is it discontinued?
    By Jeff Bower in forum New Tools
    Last Post: 10-21-2009, 03:39 PM
  5. .270 Rifle Cartridges
    Last Post: 05-01-2009, 12:53 PM
