Results 1 to 4 of 4
Thread: Proper Bolt Action
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    Proper Bolt Action
    By loosening the set screw and turning the bolt handle 180 degrees and cutting a new clip notch 180 degrees from the original clip notch.
    Now the new version of the PSI Bolt Action has 2 clip notches 180 degrees from each other making it much easier to re-orientate the clip.
    This one has Gun Metal plating with a piece of Elk antler finished with Med CA, buffed with extra fine steel wool and polished with Huts Ultra Gloss.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    Very neat idea, Les.
    3,132
    Les I really like this one.
    Aug 2008
    Reno, Nv
    3,632
    Antler was a good choice Les!
  1. Bolt Action Pen
    By Bill Arnold in forum Lathe Project Showcase
    Last Post: 07-30-2015, 02:55 PM
  2. Serpentine Bolt Action Pens
    By Terry Quiram in forum Lathe Project Showcase
    Last Post: 09-16-2014, 07:57 PM
  3. First Bolt-Action Pen
    Last Post: 09-12-2014, 04:18 PM
  4. 30-06 Bolt Action
    Last Post: 05-06-2014, 08:32 PM
  5. Proper sanding
    Last Post: 12-18-2010, 07:10 PM
