Results 1 to 6 of 6
Thread: Black and Decker ROS polishing pads
    I have the Black and Decker 5 inch hook and loop ROS. I'm trying to find polishing pads for it to be used on a Minwax finish. Thank you for any help.
    DKT
    30,014
    Pretty much any 5" or 6" hook and loop polishing pads should work with your sander. Here are a bunch to browse through:
    https://www.google.com/search?q=hook...hrome&ie=UTF-8
    Feb 2012
    2,747
    I have the same sander. Will there be an advantage to using a slightly larger buffing pad when it comes to edges and concave surfaces?
    Cheers,
    Roger
    30,014
    Based on my experience using 2 1/4" and 3" sanding disks on a 2" ROS for bowls and other turned things, I think there can be advantages to using a slightly oversized buffing pad.
    Feb 2012
    2,747
    Somebody makes a 2" ROS?
    Cheers,
    Roger
    30,014
    Yep, it's pneumatic, made by Grex. I also have a 3" Metabo electric ROS. Both are very handy for turned stuff.
  1. French Polishing
    By Dan Mooney in forum Finishing School
    Last Post: 04-21-2010, 12:31 PM
  2. Stanley buying Black & Decker (and delta, pc, dewalt, etc)
    By Jason Beam in forum General Woodworking Q&A
    Last Post: 11-03-2009, 12:20 PM
  3. Polishing a cast iron top
    Last Post: 05-04-2007, 10:38 PM
  4. Replies: 8
    Last Post: 02-23-2007, 02:13 PM
