Results 1 to 9 of 9
Thread: sic transit gloria
    Mar 2013
    445
    sic transit gloria
    One of my very first bowls to survive turning glued down in the middle of a terracotta base to feed the cat instead of the ants. At least nobody can call it a dog food bowl!
    Hu
    S E Washington State
    3,777
    That's a good idea, no ant problem, right now, but it would certainly keep them from knocking the bowl over. Not sure I understand how it keeps the ants out, do you put water in the terracotta portion?
    "We the People ......"
    Mar 2013
    445
    Quote Originally Posted by Paul Douglass View Post
    Paul,
    That is exactly it, a little water discourages the ants. I was just going to use a heavy glass or pottery bowl in the middle but naturally none were to be had that were suitable and safe to use without risking lynching. Couldn't even find a plastic container to glue down on short notice so I looked at the wood. Several candidates, this was the one I liked least. I didn't want the cat to think she was too uptown anyway, give her too fancy of a bowl and she would expect fish or steak in it every day!
    Hu
    Dec 2008
    Portland, Oregon
    1,898
    I've done a similar thing with plastic bowls, works great. How do you think the wood will stand up to the water??
    Jesus was a Woodworker
    Dec 2008
    falcon heights, minnesota
    5,610
    since it is glued down, the entertainment value of the cat chasing a floating bowl of it's food is gone....
    benedictione omnes bene
    www.burroviejowoodworking.com
    Mar 2013
    445
    Dan M,
    I don't know how it is going to hold up, I put a couple coats of lacquer on the outside of the bowl after putting a coat thinned with acetone for penetration.
    Dan N,
    You are a cruel and heartless person! I don't know how you could think of such a thing. The terracotta is too small anyway. I will have to find a bigger bottom container, no fun until she has to decide to stick a paw in the water or not . . .
    Hu
    Goodland, Kansas
    4,834
    I did one for my sister similar but used several coats of tung oil finish. It is a year old and still doing well.
    Bernie W.
    Mar 2013
    445
    Quote Originally Posted by Bernie Weishapl View Post
    Good to know about the tung oil. I didn't have any but considered linseed oil. I just coated the outside of the bowl to not have to worry about contamination if my finish broke down.
    You are braver than I am, my sister would do me great bodily harm if I tried to get her to eat out of a bowl like that!
    Hu
  1. Last Transit of Venus in my lifetime.
    Last Post: 06-06-2012, 02:25 AM
