Results 1 to 10 of 15
Thread: Dust collector upgrade
    Dec 2008
    Santa Claus, In
    4,779
    Ok, so most of you know what I was running for a DC.
    Well it just wasn't getting the job done, especially when I was using the planer and drum sander. So I purchased this from Oneida.
    I am very happy with the function. I ran a couple tests, as good as I could. I ran a bunch of MDF through the sander and planed a few boards. I did get a small amount of dust in the filter from sanding. The planer produced almost no filter dust. Before I got too crazy with some of my ideas, I made a duplicate of the bottom of the cyclone.
    I then cut a 6" hole in a 55 gal barrel top and mounted the cyclone on top.
    Here is a picture of the bag after the test. Very little dust made it there.
    Now it is time to get serious with this thing. I want to wall mount the cyclone. I made a stand for the cyclone and mounted it the the wall.
    I found some 6" HVAC duct adapters at Menards and bought two. Mounted them tot he barrel and bottom of the cyclone wall mount.
    Along with Jim's 6" hose, here it is in all it's glory.
    Dec 2008
    Santa Claus, In
    4,779
    So what I was left with after the cyclone was wall mounted.
    First thing I had to do was remove the motor from the base. The impeller had to be turned 90 degrees. I had to remove the impeller to get to the bolts that hold the impeller housing in place. When I pulled the impeller, I didn't notice I had buggered up the threads. I had to chamfer end of the shaft. So if anybody pulls their's make sure you chamfer first
    I wanted a straight pull from the motor to the cyclone. I had to purchase a 6' to 5" reducer. Found that at a local furnace dealer. I also took a small piece of the 5" to finish up the connection. I mounted two pieces of 3/4 ply to the wall, so I could mount the motor to it.
    For the filter and bag assembly, I pulled the 3 supports off the factory base and bent them with my conduit bender. I went slow as to not break the bender because the legs are thicker than regular conduit. I then figured out the spacing and cut the new legs to what I hoped would be the right length. I had the old ends welded back on too the new bent legs.
    I remounted the legs to the housing. I had to drill a couple new holes.
    Now for the question of filter mounting, I wanted to be able to remove the filter without pulling the bag. I figure I could just mount it from the outside with turnbuckles. I used four, instead of the three it came with. I bought some heavier duty type. I like the way it works and it is holding up so far. Four seems to be the ticket, good even pull all the way around. I didn't over torque them, just snug. I drilled four new holes for this.
    And here it is, all wall mounted.
    I would like to move the filter up higher but the garage door track is in the way. I can't make up my mind on whether cut the track or just remove the filter and dump the filter line outside. I also need to have a better bracket made to move the center of the mount/ impeller to be more in center with the cyclone. As of now, it is working like a champ. Next is to hard pipe the tablesaw and maybe a drop for the wheeled stuff. I will be using 4" sch 35, as I have a bunch on hand and it won't really be that long of a pull.
    10,604
    Looks like a perfect solution Steve. I'm ordering a Cyclone tonight and I am going to shamelessly copy your design
    Dec 2008
    Santa Claus, In
    4,779
    Copy all you want Bob, I think it works pretty good. For the cost, it is a great cheap upgrade
    That looks great Steve. Nice cobble job. It is amazing how little material gets to the filter with a cyclone in the path. I still shake my head when I have emptied the barrel a half a dozen times and see only a teaspoon of fines in the filter catch-bag.
    Dec 2008
    Santa Claus, In
    4,779
    Ha, I work for the state, I cobble all day long.
    13,361
    Fantastic job Steve. A great solution. Seems like it even saves some space, since you don't need much room under that filter for the bag.
    Dec 2008
    Santa Claus, In
    4,779
    Yep, the plan is to park the bandsaw there. Opened up about 6 sq ft.
    Jan 2011
    3,798
    5,321
    Seems like you could just route the exhaust directly outside, and eliminate the filter completely. It should work great - at least for the Summer, when heat loss isn't a concern. Replace the glass in that window with plex, or acrylic, and cut a hole for the hose...
  1. Dust Deputy vs. HF Dust Collector
    Last Post: 06-29-2015, 01:54 PM
  2. Dust Collector
    Last Post: 04-03-2013, 05:11 PM
  3. HF 2 hp Dust collector
    By Garry Foster in forum Hot Deals
    Last Post: 03-04-2011, 06:36 PM
  4. Dust Collector Upgrade
    By Jim DeLaney in forum New Tools
    Last Post: 04-20-2008, 12:26 AM
  5. Upgrade my Harbor Freight dust collector?
    By Dennis Thompson in forum Hot Deals
    Last Post: 04-06-2008, 06:10 PM
