Results 1 to 5 of 5
Thread: mills
    NH
    4,005
    mills
    So I put it to the collective brain trust. How does (and with what) one glue in the mill parts?
    Stupid hurts.
    Independence, Kentucky
    1,354
    For the Crush grind mills, I cut a groove for the two clips to snap into and I also add a small amount of epoxy in the grooves just for good measure, and have not had any problem with them coming loose.
    North West Indiana
    6,098
    The ones I have made, the old style crank that sits on top like an open gear, it screws onto the wood with two screws. The salt shaker on top and grinder on bottom, has a shaft that runs vertical and through the edges of the holes it is "pinched" together. The other style with a handle on top, think it is two screws underneath the chrome top. No epoxy here (yet).
    Jon
    Aug 2008
    Reno, Nv
    3,632
    Awww crap...did one pop out on the salt mill? I just made the tool to set the grind mechanism the "book" way. I can remount it and turn the recess so the side clips will set.
    Goodland, Kansas
    4,834
    I cut a groove and then apply epoxy in the groove. Never had a failure.
    Bernie W.
  1. new run of pepper mills
    By Dan Noren in forum Lathe Project Showcase
    Last Post: 10-06-2014, 05:42 PM
  2. And a few pepper mills
    By Chuck Ellis in forum Lathe Project Showcase
    Last Post: 11-27-2012, 12:36 AM
  3. A Mess of Mills
    By Don Orr in forum Lathe Project Showcase
    Last Post: 11-30-2011, 03:35 AM
  4. Two more mills
    Last Post: 10-07-2011, 12:28 AM
  5. pepper mills
    By larry merlau in forum Turning Tool Questions and Show & Tell
    Last Post: 06-21-2009, 04:55 AM
