Results 1 to 9 of 9
Thread: Best Bandsaw Blade for Bowl Blank Prep?
    Jun 2012
    Laurinburg NC
    316
    I have an older Delta bandsaw that takes a 93 1/2" blade. I looked some at the big box store (Lowes) to figure out best blade to prep a bowl blank...easy prepping like cutting corners to fit lathe. I know this saw wont do but so much but it is what I have for now...Any help is appreciated...Thanks
    5,167
    3 TPI blade. Cutting blanks is tough work. The stock is thick and often green [wet]. Need big gullets to evacuate the sawdust in the cut. 3 tpI b;ade and don't overfeed the blade. It'll work great.
    Aug 2008
    Reno, Nv
    3,632
    +1 ^. I have our local tool shop make them for me...$12-15 a pop and they work a lot better than Woodslicer.
    30,002
    Forget about the big box store. They won't have anything suitable. And if you go to Rockler or Woodcraft or any of the other woodworking specialty stores, you'll pay three or four times what the blade should cost. As Carol said, a 3 tpi is what you're looking for. I use a 1/2", although some guys use a 3/8" for cutting tighter curves (smaller blanks).
    I buy my blades from these guys:
    http://ellissaw.com/
    I use the "Flexback" blades at the bottom of this page:
    http://www.ellissaw.com/Band-Saw-Bla...ade-stock-list
    The 105" blades for my saw cost $7 or $8 each. Ellis has a $50 minimum, so I stock up when I buy blades. They also don't have online ordering...you'll have to call them to order. And as Jim said, sometimes you can find a local tool or welding supply shop to make them for you, and they will be less expensive than what the woodworking stores will charge you.
    @Jim, the Woodslicer is not suitable at all for cutting bowl blanks. It's a resaw blade. Are you thinking of the Timberwolf instead? It's a great blade for green wood...just overpriced by about 4X.
    Aug 2008
    Reno, Nv
    3,632
    I was using it for resaw stuff down to pen blank size. I had a saw tech come out and see why it wouldn't track and was burning. He took my Griz apart, re-did everything and it still wouldn't track or cut. He said the saw was great, set up just right, just a POC blade. The four I use from the shop are fantastic!
    May 2009
    Lafayette, Indiana
    2,379
    Ellis blades are a good buy. Price is right and they cut as well as the big name blades. I have used a 3/4" blade for bowl blanks.
    Goodland, Kansas
    4,834
    I use timberwolf blades for years. Excellent blades.
    Bernie W.
    Tellico Plains, Tennessee
    4,351
    +2 here... anything more will bind and likely create a safety hazard...
    And also +1 with Vaughn's statement... I buy my blades from Packardwood... Olsen brand (I think)... they work good, last a while and aren't all that expensive. I've bought the big box store blades and they don't last... plus now that I have a riser on my Delta 14", I need the 105 inch blades and the big box stores usually don't carry them.
    Chuck
    Tellico Plains, TN
    30,002
    Quote Originally Posted by Bernie Weishapl View Post
    T-wolves are great blades, but we'll get you converted over to Ellis blades eventually, Bernie. For the same price you spend on two blades, I get six or seven.
  1. Bandsaw Blade ?
    Last Post: 03-28-2015, 08:41 PM
  2. What's worse than finding a grub in a bowl blank?
    By Ned Bulken in forum General Woodturning Q&A
    Last Post: 09-26-2014, 04:08 PM
  3. Thinking About Buying A Chainsaw for Bowl Prep Work?
    Last Post: 08-08-2013, 02:07 AM
  4. Bowl Blank Questions
    By Bill Grumbine in forum General Woodturning Q&A
    Last Post: 12-31-2006, 05:12 AM
  5. What bandsaw blade?
    By George Conklin in forum General Woodturning Q&A
    Last Post: 11-26-2006, 01:07 AM
