Results 1 to 10 of 17
Thread: Stickley Table - Refinish Problem
    13,357
    So, A friend of mine recently moved across the country. She had purchased a pretty nice Stickly table with some inlays in the corners.
    During the move, the mover managed to mistreat the table and ding it up pretty bad.
    When confronted with the damage, the mover had a local 'Wood Doctor' work on the table to fix the gouges.
    The wood doctor said that they contacted stickley for advice on a finish to use to fix the table.
    Now, here are the befores and afters.
    It appear that the 'Wood Doctor' sanded the entire table top to remove the finish, stained it a slightly different color, and put in a different finish.
    The owner has noticed that the 'new' finish has a completely different feel. Apparently, before it had a very nice smooth, almost glassy feel.
    Now it is dull, and the wood doctor has told her to just 'wax' it to get it to have the same feel.
    The other problem as I see it is that the inlay used to have some very sharp and crisp colors. It looks to me that the light colors have now been muddied up either by sanding the darker woods into it's pores, or from some kind of stain the 'wood doctor' applied.
    We have no idea what kind of topcoat this 'wood doctor' applied, but what we do know is that it no longer has the same smooth tactile feel it had before the move.
    The questions are:
    1) Do you think this table has been damaged? Should the shipping company have to make amends above and beyond the damange this wood doctor has done.
    2) Can this table be fixed? I.e. Can this stain and finish be removed? Can the inlay be salvaged? Could another skilled artisan fix the damage?
    Any suggestions/help would be appreciated.
    Thanks in advance for your help.
    Table Before
    Table After I know it could be the camera, but the red color is gone and now it's more of an 'oakey brown'
    Inlay before, Clean lines, light colored sections are light colored
    Inlay after. The light colors are stained somewhat darker, the dark colors are very dark and muddy.
    4,698
    Looking at the inlay I'm going to bet that the discoloration there is due to whatever stain/topcoat the "wood doctor" (butcher?) used. I don't know how fixable it is, I suspect that depends on how deep the new stain went in, might be lucky might not - I do look forward to seeing what some of the experts have to say on this one.
    Personally I'd be pursuing $$'s for loss of value and proper restoration of this piece, although I don't know exactly how much its worth I'm sure its not a cheap piece!!
    Brent: Thank you for posting this!
    Kind people of the forum: It's my sad table. FWIW, I used the exact same camera to take all the pics, although the lighting in the new place is a little dimmer, it's not much better in my old place--that was a dim room for sure. I can try to get some pics in daylight but if it would help, I have several other pieces that use the same finish from Stickley and I can pull out the leaves and do a "compare and contrast" for both color and shine if that would help. He unfortunately had to fix all of the pieces to some extent and most of them are fine...they were small dents, scratches, etc and he did ok with those since there was no sanding down or complete refinishing needed.
    One other thing: the bedroom end tables he worked on are now scratching crazy easily--they are much less resilient than previously. I think all he did for those was fill in some scratches and buff them out. Is there anything I can do to save those without trying to get the company to replace?
    It was a corporate move, and I suspect they will give me a super hard time for any additional asks I have, but I'm really bummed about the table. Ryan...it definitely wasn't cheap!
    I really appreciate any advice at all on what can be done at this point.
    Thank you so much!
    5,169
    Hope Dave Hawksford chimes in. Hope I got the last name right. He is our resident expert on finishes and especially refinishing. He is also a very talented artist.
    Dec 2008
    falcon heights, minnesota
    5,609
    i was just thinking of dave. he would be the one to go to. it looks to me like a combination of sanding dust and topcoat for that inlay problem.
    benedictione omnes bene
    www.burroviejowoodworking.com
    30,008
    Looks to me like they stained the inlay with the same Minwax crap they used on the rest of the top. And the color "match" on the top is so far off, I suspect a colorblind llama picked out the stain. Hopefully Dave can chime in with advice, but I'd be livid about the job this so-called "doctor" performed. The color mismatch is inexcusable; staining the inlays is borderline criminal.
    The tactile difference is probably because the new clear coat was not rubbed out and buffed to the same glass-like flatness that the original finish had.
    The moving company carries insurance to cover this sort of thing. Personally, I'd cut them no slack until the table was either repaired back to original condition or replaced. And no way would I let this particular wood doctor touch it again.
    17,471
    i agree with vaughn on this trouble, michelle. and dave hawksford would make it right for you but there is a lady in nevada that does very nice work will need to get her name, she teaches woodworking.
    Austin, Texas
    1,448
    Michele, welcome to the forum
    I agree that it looks like they sanded and stained the top - doing a terrible job at it.
    A corporate move gives you much more leverage than a private move... the moving company gives corporations a special price to get "all" their business, accepts normal payment (rather than small unmarked bills of a total you don't know in advance, before they unload the furniture), etc. Therefore the mover (or your corporate liaison with the movers) have LOTS more leverage - the mover wants to protect their corporate client. They should be liable for both the damage of the mover, and the damage caused by the incompetent repair service (even if the repair service is a national franchise).
    Wood Doctor is a franchise... when they are looking to expand, it is amazing how short their training program can become (they have tried to sell me a franchise in the past). I would refuse to let them touch my table - you already complained to them, and gave them the opportunity to fix it, and it is obvious from the answer that they don't see or understand the problem.
    I am not a refinishing expert, although I do some... Dave's advice will be better. But I expect the best solution would be a chemical finish remover - which generally removes stain in addition to the mystery top coat. With the finish gone, if dye was used, there will still be some color which can generally be removed with bleach (Clorox laundry bleach, not intense wood bleach). For example, if Minwax was used, it is a combo of both stain and dye, so both processes may be required. I would then check if the color can be brought out with a good sanding sealer rather than a stain or dye. The color surrounding the inlay "before" looks like it could be natural Cherry wood, perhaps aged a bit after a clear finish was applied - my sister has a Stickley table with the same inlay, and it is cherry, so with cherry the pretty tan color emerges in a few months after a clear finish is applied.
    Good luck
    Let us know the moving company - for additional leverage (especially when you post how well they resolved your problem).
    Charlie Plesums, Austin Texas
    Austin, Texas
    1,448
    ... there is a lady in nevada that does very nice work will need to get her name, she teaches woodworking.
    That lady's name wouldn't be Carol Reed, would it?
    4,552
    On your end table he probably just used a touch up stick and then gave it a shot of rattle can lacquer and more than likely the original finish was Catalyzed lacquer. It will never hold up like the original finish. I would be all over that moving co to make this right and that table will take a LOT to get it back to where it was, if you can get there at all.
    A Turn N Time
    Frog Pond Guitars
  1. Refinishing a Stickley Coffee Table
    By Laura Simon in forum General Woodworking Q&A
    Last Post: 03-01-2017, 03:19 AM
  2. Stickley #599 Trestle Table Build
    By Gary Zimmel in forum Flatwork Project Showcase
    Last Post: 11-23-2012, 02:52 PM
  3. Table and Chair Refinish
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 07-18-2011, 02:19 AM
  4. A refinish project - table top
    By Rick Prosser in forum General Woodworking Q&A
    Last Post: 06-12-2011, 04:12 AM
  5. refinish table
    By ken lutes in forum Finishing School
    Last Post: 12-30-2009, 06:06 PM
