Results 1 to 10 of 13
Thread: looking for a power washer
    new york city burbs
    10,188
    I managed to finish spraying off that green muck off my vinyl siding today, but the cheap electric power washer Ive owned for 18 years kept shutting off. It was leaking pretty bad from the bottom, not the hose connection, and when I finally went to unplug it, it popped in my hand and I got a nice shock. That's that. Its going into trash, wont even try to fix it.
    Im looking for a gas powered power washer, don't need some industrial powered one.
    Just to wash off blacktop once or twice a year, and to wash down vinyl siding.
    any suggestions? (I know nothing about power washers, other than point and spray)
    Human Test Dummy
    5,320
    Not the best, but I've had a Campbell-Hausfield one for several years, and it's been reliable. 2200psi@ 2.25gpm, with a 5.5hp Honda engine on it. Used it last week for the first time this year, and it started on the second pull. Hadn't run since about last August, so I was very happy to see it start so easily. Sam's Club has several models of them fairly cheap. The 2600psi Simpson looks good.
    Southeast Pa
    2,019
    All I know is the Honda or Honda clone engines are hard to beat...
    4,698
    Karcher here with a small Honda engine. I use it 2-3 times per year and it always starts on the first pull (assuming I remember to flip the switch to on... ).
    new york city burbs
    10,188
    its mind boggling everyplace sells them, every online shop sells them, and there are so many brands.
    I figure labor day weekend might be the time to get one at a decent price. sales are usually decent.
    Human Test Dummy
    Thomasville, GA
    5,992
    I have a Troy-Bilt 2600psi, 2.3gpm unit with a Honda engine. It came with four nozzles for different applications. It works great on my concrete driveway as well as the aluminum siding and brick on the house.
    That being said, the best way I've found to clean the vinyl siding on the house and Hardee siding on my shop is a product called JO Max. It's a mildewcide, among other things. You mix a little with a bleach/water mixture and spray it on the area to be treated. I spray it on the siding with a garden sprayer. In minutes, I can see mildew and other yuck melting away. Then, a quick hit with the power washer and the job is done.
    Bill Arnold
    12,251
    Bill do you think the JOMax would work for the black streaks on a trailer with aluminum siding? I tried some of the black streak stuff they sell at the RV stores but its a waste of time.
    Sorry for the hijack Allen.
    13,439
    I've got a honda I bought 5 years ago from HD, still starts on the first pull. I use the "pump saver" in it every winter to blow out the water and fill it with polyglycol. It has the multi tip head, that you press, spin to the head you need and snap it back down, very handy.
    13,439
    My dad mixes Mr. Clean and dawn dish soap with water. It always removes the black streaks/mildew, as well as any oxidation from the surface of the paint.
    5,172
    Is that a 50/50 mix, Darren, and how does he apply it? The MH needs a thorough cleaning.
  1. low tech parts washer
    Last Post: 01-30-2016, 03:59 PM
  2. Parts Washer Question
    Last Post: 01-18-2011, 04:49 AM
  3. Pressure Washer Preferences?
    Last Post: 06-16-2010, 11:50 PM
  4. Washer type mechanism, need help!
    By Westley Rosenbaum in forum General Woodworking Q&A
    Last Post: 02-16-2010, 07:40 PM
  5. GE washer/dryer sale
    By Kirk Constable in forum Off Topic Discussion
    Last Post: 02-05-2010, 06:06 AM
