Results 1 to 10 of 10
Thread: Board down!
    5,533
    Board down!
    Had a glue failure today... Heat related? TbIII Click image for larger version.
    I'm debating on how to fix it...
    -Ned
    Sep 2007
    Plainwell, Michigan
    4,857
    Re cut and re glue the joint, one thing you do not want on ANY cutting board is a crack or gap of ANY size, that is an opening for bad germs and sickness...
    13,363
    Depending on the size of the board, maybe trim it off and sell it as a trivet.
    5,175
    That looks like a wood drying issue, given the orientation of the grain. Let it sit for a few months. Then re-rip it and glue again.
    NH
    4,012
    What she said.
    Stupid hurts.
    17,475
    What she said.
    yup!! you cant reinvent nature
    While I agree with Carol and the others that this looks like a case of wood drying, I also wanted to mention that when I was making a lot of cutting boards, I found I preferred Titebond II over Titebond III. TBII has a longer working time. I found on some glue-ups that TBIII was starting to set up before I could get everything in the clamps. I realize TBIII is more waterproof, but unless the cutting board is stored underwater, TBII is plenty water resistant.
    May 2011
    Cape Cod, Ma.
    1,553
    I would re rip and glue. a piece that small has probably done its moving or isn't going to move much more. have you ever thought of using epoxy on the joints instead of wood glue. Although epoxy doesn't carry an fda rating it is inert when fully cured.
    just a thought.
    http://www.westsystem.com/ss/wood-ep...nk-guidelines/
    NH
    4,012
    And again what he said.
    Stupid hurts.
    5,533
    it and a few others are going back to the shop for a rework or two... in this case, I do think it was wood drying, from being out in the sun... the board dried out and part of it moved, more than a little, in just a few hours. Easy fix is going to be trim it down, glue it back together and it will be good.
    as for tbIII, I bought a gallon of the stuff, so until what is left( About 2/3 of a gallon) is gone, I'm sticking with it. (no pun intended). I'm no longer in a 'rush mode'... so I'll have plenty of time to get the boards glued up and clamped when I get back to making them. I'm taking a break, I have several shop projects I want to accomplish before I do many more cutting boards. The most I'm planning on doing is to glue up some blanks and set them aside after they come out of the clamps, since I have a pretty good batch's worth in strips waiting for glue.
    -Ned
  1. Vertical Chest Board and Chalk Board
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 02-25-2012, 10:56 PM
  2. Ode to Peg Board
    Last Post: 11-21-2010, 06:15 PM
  3. Getting On-Board
    By Bruce Niceley in forum Welcome and Introductions
    Last Post: 11-21-2008, 07:04 PM
  4. how to rip 6' board
    By Eduard Nemirovsky in forum General Woodworking Q&A
    Last Post: 08-11-2008, 12:41 AM
  5. First Board
    By randy street in forum Flatwork Project Showcase
    Last Post: 03-26-2008, 04:21 PM
