Results 1 to 10 of 13
Thread: Just want to be sure.
    S E Washington State
    3,777
    I'm making a little jewelry box for my granddaughter. The plans I have says to rout a 1/4" rabbet, 5/32" deep along the outside bottom edges. I think that means 1/4" up the side and 5/32" into the side. So there will be a groove 1/4" high, 5/32" deep along the bottom. Am I correct or is it the other way around, 5/32" up the side and 1/4" into the side? I started to rout it but got nervous. Really don't want one of these
    "We the People ......"
    4,698
    "there will be a groove 1/4" high, 5/32" deep along the bottom" <- that's how I read it. Cross check the math on what the dimensions of the piece used for the bottom are.
    10,600
    My way of thinking is that if it said make a 1/4" dado 5/32" deep it would be obvious how to do it. By replacing dado with rabbet it should be a 1/4" wide rabbet (across the top of the board) 5/32 deep. So I would say it's the second option you mentioned.
    3,777
    Now I'm really nervous... it's 1 to 1. Guess I will have to do the math after I get a couple cups of coffee in me.
    Thomasville, GA
    5,992
    It sounds to me like the intent is to make the bottom panel (1/4" thick) flush to the bottom edge of the sides. A 1/4" rabbet, 5/32" deep is the way to do that, of course. Making the bottom panel flush with the bottom of the sides will take some careful trimming to get a perfect match but it will be worth the effort.
    Bill Arnold
    17,470
    paul relax take and see what the bottom size is for the bottom is it 1/4" solide wood or is it plywood? if its ply the plywood now days is thinner and would be the 5/32 thickness if its solid wood then it would be the 1/4" use some scrap paper to check this out for fit before making a cut.. to me i agree with bob if it says rabbet its going the second way you thought.. a dado is a grove that is a predetermined width and is cut to a certain depth.
    Dec 2012
    Bedford, NH
    1,683
    I'm going to make it 2/1. Since a rabbet is just a dado cut along the edge of a board & a dado is defined as width x depth, then a rabbet should be (to maintain standard descriptions) defined the same way, i.e. width x depth (same as with a groove as well). So, I'm on the same page as Bob and agree with your second interpretation. I'm betting the math will prove this.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    13,436
    I interpreted it as 1/4 wide (thickness of your bottom piece) and 5/32 wider on each side than the un-cut bottom of your box, so the bottom will end up 5/16 (5/32 + 5/32) larger total in each direction when cut to size (assuming rectangle or square...or hex, octagon, etc ).
    Edit: Where is a sketchup drawing when you need one (hint...I don't have it installed here at work).
    5,167
    Draw a cross section story board. Don't need SketchUp for that.
    Thomasville, GA
    5,992
    Maybe this will help visualize it:
    Two sides with the bottom inset to them.
    Bill Arnold
