Results 1 to 7 of 7
Thread: iBox jig users
    5,175
    iBox jig users
    What is the perfect Freud blade that goes with this thing? I think it is Freud.
    13,364
    This is what I use. It does a good job of making flat bottom cuts. I've had some issue with tear out using it on 1/2" baltic birch, but I could probably take care of that with an appropriate backer.
    http://www.amazon.com/Freud-SBOX8-Cu.../dp/B000ASGV1E
    (That may not be the cheapest place to get it, but it was the first to come up)
    5,323
    This is what I use. It does a good job of making flat bottom cuts....
    That's the one I use, too.
    Brent's tear out problem can be solved by using a new backer board. I made up a batch (a dozen or so) out of tempered hardboard. The Ibox instruction booklet has the dimensions for the - or you can use an old one as a template.
    12,264
    Just as a matter of interest and concern why must it be box cutters. Whats wrong with dado blades?
    9,077
    A good quality dado works fine for me. I made 20 backers before I ever used the jig. The lack of a sacrificial "shelf" is a disappointment and can still give a bit of fuzz even with a backer but, overall a good backer will cure your ills.
    10,604
    That's the one I bought with the jig. Haven't even opened the package yet though
    13,364
    A dado would work fine Rob.
    Some dado blades don't make a perfectly flat cut, and may have slight little 'points' ground on the outside edges of the outside blades. Not really a big deal though.
    These box cutter blades though also make it very easy to dial in the 2 widths without having to adjust with shims. Put them together one way and you get 3/8", the other way, 1/4".
  1. Any Mac users here?
    Last Post: 05-24-2016, 04:19 AM
  2. Dedicated iBox marriage - DONE
    By Carol Reed in forum Jigs and Fixtures
    Last Post: 09-08-2014, 04:07 AM
  3. iBox jig users
    Last Post: 09-03-2014, 10:36 PM
  4. Incra iBox
    By Bill Arnold in forum Jigs and Fixtures
    Last Post: 11-07-2013, 03:04 PM
  5. IBox owners! Got a question
    By Carol Reed in forum General Woodworking Q&A
    Last Post: 10-10-2012, 10:29 PM
