Results 1 to 10 of 25
Thread: HFDC Casters
    Dec 2012
    Bedford, NH
    1,683
    HFDC Casters
    I just finished assembling the HF Dust Collector (http://www.harborfreight.com/2-hp-in...tor-97869.html). It took a while to get to this installation as I had to "rearrange" the shop first to set up a place to locate it. The assembly went well, rather easy actually, but I am disappointed with the casters & the 4" wye that came with it. And, for some reason - perhaps assuming too much - the system is louder than I expected
    All four casters are the "locking" type and do not swivel well (I made sure they were not locked). I may install larger dia. casters that I have on hand, or change the whole installation to something similar to what Brent did. I liked his installation and tried to find Brent's post but couldn't; must be buried in another thread. Anyone know where it's located?
    Also, the 4" wye seems quite a bit loose to hold suction. It seems like I may have to wrap some tape to tighten things up.
    I'm curious if any of you that have this DC experienced the same things.
    Thoughts entering one's mind need not exit one's mouth!
    As I age my memory fades .... and that's a load off my mind!
    "We Live In The Land Of The Free, Only Because Of The Brave"
    “The problems we face today are there because the people who work for a living are outnumbered by those who vote for a living."
    Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
    13,365
    Perhaps you are looking for Steves dust collector upgrade thread?
    http://familywoodworking.org/forums/...lector-upgrade
    13,467
    Mine do the same and I was actually thinking of "upgrading" my HF DC's casters just yesterday. I've got a really rough shop floor, so figured it was just that they were too small and plan to put a bigger set on them. The noise is loud, but not any louder than any others I've heard to be honest. I thought about adding some plywood under the base to stiffen it up some and not make the base an extra noise diaphragm.
    S E Washington State
    3,777
    I've had that DC for years and just a few months ago the switch went out. Not a problem to replace. But from what I have read over the years it is common. I added the thien baffle to mine last month and wish I had done it year ago. I also attached my Wynn filter with bungee cords while I was at it I also wish I had done that years ago. I think the thien baffle quieted mine down a little. But I'm also pretty sure all dust collectors are noisy. You will definitely want and need to add the Wynn or equivalent filter system to it. 5 micro bags are not good. If you have the room and time the complete conversion you are thinking of would be the best option in my opinion. I have not had a problem with things being loose. I too would like to put better casters on mine although I rarely move it other than to vacuum under it.
    "We the People ......"
    Dec 2012
    Bedford, NH
    1,683
    Thanks Brent! Yup that was the thread, but for some season it's changed from what I recalled. If I had to guess, my memory failed me again! With my setup, I won't be able to do what Steve did. I'll just work around what is there.
    As for Paul's suggestion regarding the Wynn filter, I plan on doing that, perhaps around Christmas. I don't use the shop much, so time is not of the essence.
    I have to think more about how much the DC will be moved, probably not enough to warrant using the bigger/better casters. They would probably be more useful on a different project.
    13,467
    Here is the tutorial for the Thien Baffle...
    http://familywoodworking.org/forums/...t=thein+baffle
    3,777
    Al, another thing to give consideration to, if you can't pipe yours in and have to drag a flex hose around, like I do, this is the best way to go IMHO. You need the fitting that go with it.
    http://www.rockler.com/product.cfm?p...6&site=ROCKLER
    Dec 2012
    Bedford, NH
    1,683
    Thanks Paul, that sounds like a good idea. However, a questions that occurs to me is whether repeated extensions of the hose, especially at longer lengths, will cause a set to the hose preventing full retraction to its original short length. Have you encountered this?
    3,777
    Mine does not retract as much as they show, but I don't have a hanger for it. I could push it back to the retracted size, but I leave it hooked to my table saw most the time and only move it to other tools as I need to. I use to have a length of that black flex hose, what a battle to move it from place to place! This is very easy to move around, and bends more so it will easily go around other equipment, which the old black hose would not. I've been thinking about making a hanger for it, but I probably wouldn't use it as much as I do now if I had to go get it every time. Oh, that makes me think of another great thing I added, a remote switch to turn the DC on and off. I love it.
    Dec 2012
    Bedford, NH
    1,683
    As far as the noise is concerned, perhaps my best remedy is to simply remove my hearing aids. I have hearing muffs that I may use???
    Paul your thought about a remote switch to start/stop the DC is a good one. That is exactly what I'm in the process of doing. I installed one for the air compressor which is out in the garage. It's very handy to be able to just reach up to the switch (have it mounted to the bottom of a girder beam) to turn on the "remote" compressor. Although the DC will be located in the shop, it will still be handy to have the switch located centrally to the power tools.
    PS As an aside, I was in Lowes & Home Depot checking out the electrical components that I'll need to wire up the DC. I was surprised at the cost of the 12/2 WG cabling, http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1 almost $0.70/ft. I need 30' so I would have to buy a 50' roll @ $33.97. I found a 75' roll on eBay for $32.99 http://www.ebay.com/itm/12-2-WITH-GR...-/171072189034? with free shipping (will receive in less than a week). 35%/ft. less - I love a good deal!
  1. And one for you casters
    By Darren Wright in forum General Woodturning Q&A
    Last Post: 09-25-2015, 04:54 PM
  2. HF DC Casters
    Last Post: 04-29-2014, 06:46 PM
  3. What is the Word on Casters
    By Paul Douglass in forum Jigs and Fixtures
    Last Post: 11-17-2013, 05:35 PM
  4. Peachtree Casters 50% off
    Last Post: 11-30-2011, 12:41 AM
  5. Casters
    Last Post: 10-12-2007, 11:59 PM
