Results 1 to 10 of 10
Thread: Spalted maple question
    Aug 2011
    Hitchins, Kentucky (Northeastern part of the state.)
    80
    Question Spalted maple question
    A fried of mine is going to give me a slab of spalted maple. Do you have to stabilize it before you turn it? I was thinking of getting some pen blanks out of it.
    Oliver Springs, TN
    1,726
    It depends on how far the spalting (rotting) has gone.
    Aug 2008
    Reno, Nv
    3,632
    If it's punky, it'll need the treatment. I stabilize commerically so let me know if you need a hand.
    Aug 2011
    80
    Thanks, guys. Once I get it, I'll see how soft it is. Is there a good way to determine how soft it would have to be to need the treatment? (For example, if it yields to your thumbnail.)
    11,825
    I stabilize and have seen a lot of spalted maple, it likes to spalt rapidly. Yes, I would stabilize.
    Aug 2008
    Reno, Nv
    3,632
    Quote Originally Posted by Raymond Scott View Post
    I would turn a piece and see how much tear-out shows up...if it turns and sands well, you're off the hook!
    Oliver Springs, TN
    1,726
    I agree with Jim. Try a piece first.
    I've used thin CA glue on smaller pieces to harden it up as I went if the rot wasn't really bad.
    30,002
    Quote Originally Posted by John Daugherty View Post
    And I agree with John. Of the spalted maple I've turned, I don't think any of it was punky enough to warrant stabilization. Spalted hackberry, on the other hand, is a different story for me. Punkier than a busload of gangbangers.
    Like others have said ... depends.
    Turn a piece and try it. If it tears/falls off easily you'll need to do some stabilizing.
    For quick use I use thin CA as I turn.
    When I don't want to use my stabilizing fluid on one or two pieces I will get 30 Minute Epoxy when its on sale from HF and squeeze the tubes in a plastic cup ... because I'm inherently frugal (cheap) I'll add 91% Isopropyl to the epoxy and keep stirring until it's the consistency of water and then paint it on the pen blanks with a foam brush.
    It will drink it up and after drying it really helps when turning with using CA just on the really rotten parts.
    30,002
    Quote Originally Posted by Ron Hossack View Post
    ...I'll add 91% Isopropyl to the epoxy and keep stirring until it's the consistency of water...
    I've done the same using denatured alcohol.
  1. More Spalted Maple
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 08-25-2015, 12:28 AM
  2. Spalted Maple & Fiddleback Maple pieces..
    By Chip Sutherland in forum Lathe Project Showcase
    Last Post: 04-08-2013, 03:07 AM
  3. Spalted maple DT box
    By ken werner in forum Handtool Project Showcase
    Last Post: 04-22-2010, 05:41 PM
  4. Spalted maple
    Last Post: 08-18-2009, 01:11 PM
  5. Spalted Maple
    By Richard Smith in forum General Woodturning Q&A
    Last Post: 03-23-2007, 12:51 PM
